blingy Posted December 1, 2013 Report Posted December 1, 2013 First, I am trying to get my seq v4 to be sync'd to my v4l over Ethernet by directly connecting the two. Is this even possible without a router? I'm temporarily out of midi ports on both, so I'm trying to use the network adapter to get around this...I've got the IPs set, although my network configuration isn't saving in the session after a power cycle of the v4l. I'm likely going about this the wrong way though... Is anyone else using both at the same time sync'd? PS the duplicate function is amazing! Mmmm
TK. Posted December 1, 2013 Report Posted December 1, 2013 OSC for synching devices doesn't work robust enough, especially since the ethernet interface is handled with a lower priority than other MIDI tasks. Therefore I haven't implemented such a possibility, and I can't change this since with a higher priority the network traffic could influence the performance of the sequencer too much. Best Regards, Thorsten.
blingy Posted December 2, 2013 Author Report Posted December 2, 2013 Thanks TK, guess I need to finish adding more midi ports!
