PaulBeaney Posted February 18, 2014 Posted February 18, 2014 Hi, Been a MIDIbox user for a few years now (thanks, TK!) but this is the first time I've not found my question already answered somewhere. Having been on MIOS8 for so long, I recently got an STM32F4 Discovery to start work on replacing my existing board. It was all going really well until I tried add an RTOS task with (I presume) not enough stack memory allocated, resulting in a "hard fault at PC=0x00000000". I've amended my code to allocate a bigger stack, but now I seem to have no way to upload any more. The error condition occurs very soon after bootup (in App_Init()), but using the reset button on the Discovery board doesn't seem to trigger an upload request - MIOS Studio doesn't respond in any case. I'm guessing my config must have fastboot turned on. I found a mention of the "BSL Hold" jumper here http://www.ucapps.de/mios32_bootstrap_newbies.html, but that seems to be for the LPC17 board only. Is there any equivalent on the Discovery?? Hoping someone can help! Regards, - Paul
PaulBeaney Posted February 18, 2014 Author Posted February 18, 2014 Ah, just realised that I didn't actually need to make a first post - I've just this moment seen the bit on that page I linked to that mentions using the User and Reset buttons to force bootloader mode... and it works a treat!
TK. Posted February 18, 2014 Posted February 18, 2014 This reminds me, that I wanted to implement a fallback mode, so that USB MIDI access is still possible, and also some terminal commands for debugging are available (e.g. to dump a memory map for stack analysis) Maybe a nice weekend project :) Best Regards, Thorsten.
PaulBeaney Posted February 25, 2014 Author Posted February 25, 2014 Whilst I can now recover the board after a crash, I am still getting these "hard fault at PC=0x00000000" errors whenever I try and create an RTOS task. Running umm_info() before attempting to launch the task gives this: [24733.109] Dumping the umm_heap... [24733.109] |0x20000910|B 0|NB 0|PB 0|Z 0|NF 0|PF 0| [24733.110] |0x20000910|B 0|NB 0|PB 0|Z 2048|NF 0|PF 0| [24733.110] Total Entries 0 Used Entries 0 Free Entries 0 [24733.110] Total Blocks 2048 Used Blocks 0 Free Blocks 2048 [24733.110] Size of umm_heap is 24576 bytes, used: 0 bytes, free: 24576 bytes I have fiddled with the values of the stack size in the task creation and the only extra information I have been able to ascertain is that if I request too much memory, or none at all, then there is no crash (but nothing useful happens either), which seems to indicate that the crash is only happening when there *is* available memory. e.g. xTaskCreate(TASK_LED_Update, (signed portCHAR *)"LED", 4*1536, NULL, PRIORITY_TASK_LED_UPDATE, NULL); gives the error in MIOS Studio console: [25057.685] Can't allocate 2049 blocks at 305 Any ideas welcome!
TK. Posted March 2, 2014 Posted March 2, 2014 By default following stack size is used (see programming_models/traditional/FreeRTOSConfig.h): #ifndef MIOS32_MINIMAL_STACK_SIZE #define MIOS32_MINIMAL_STACK_SIZE 1024 #endif ... #define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) (MIOS32_MINIMAL_STACK_SIZE/4) ) as you can see, the byte size has to be divided by 4, because FreeRTOS counts the memory word-wise Which means, that you tried to allocate 24580 bytes - which fails (for obvious reasons). Note that programming_models/traditional/main.c creates two additional tasks for MIDI and other purposes, which need memory from the heap as well (1024 bytes per task as defined with MIOS32_MINIMAL_STACK_SIZE) Best Regards, Thorsten.
