Marxon Posted February 26, 2014 Report Posted February 26, 2014 (edited) Hi all! I want to make a button which sends a NRPN event. The value of this event should, however be set with another encoder. Because using ngr scripts was a good choice in the past, i tried this: EVENT_ENC id=116 hw_id= 14 type=Meta meta=runsection:206 range=map1 no_dump=1 enc_mode=Absolute label="^std_enc" EVENT_BUTTON id=123 hw_id=123 type=NRPN nrpn= 45 nrpn_format=MsbOnly no_dump=1 button_mode=OnOnly label="^std_btn" if ^section == 206 set Button:123 ^value endif But somehow it does not work like suspected. 1) Turning the encoder also triggers the button event but it was intended that it set the button's value only. Maybe i misunderstood the SET and TRIGGER commands? 2) Although MiosStudio reports ("show id button:123") a correct value after turning the encoder, the button always sends value 127 and not the value of the encoder. Thanks for any advice! Best reragds Marxon Edited February 26, 2014 by Marxon Quote
TK. Posted March 2, 2014 Report Posted March 2, 2014 to 1) I added the following to the wishlist: - "silent set value" (don't send MIDI event when value is changed) to 2) you've specified "nrpn_format=MsbOnly" - could this be the reason? Best Regards, Thorsten. Quote
TK. Posted March 6, 2014 Report Posted March 6, 2014 Please try this version: http://www.ucapps.de/mios32/midibox_ng_v1_030_pre2.zip The "silent set" can now be done with: change Button:123 ^value and the reason for 2) was, that the button will always send the "max" value of the specified range (0:127 by default). The new: set_max Button:123 ^value command will allow you to change the range Best Regards, Thorsten. Quote
Marxon Posted March 7, 2014 Author Report Posted March 7, 2014 OK thank you TK! :smile: I will test the new release this evening! Best regards Marxon Quote
Marxon Posted March 8, 2014 Author Report Posted March 8, 2014 Like always, great work Thorsten :thumbsup: Silently set a button´s value via an encoder works like expected. I use the ngc code from my first post together with this ngr script: if ^section == 206 set_max Button:123 ^value change Button:123 ^value endif Thank you! Best regards Marxon Quote
