cosmosuave Posted March 10, 2014 Posted March 10, 2014 More questions arise as I am completing my SEQV4 after looking at the documentation I am trying to figure out which jumper connection on MBHP_CORE_LPC17 does the MIDI Quad IIc connect to? I need to get the right connectors for this.. Is it J4B on the core or pins on J5B or a combination of both? Thanks... Brian
Shuriken Posted March 10, 2014 Posted March 10, 2014 (edited) The LPC17 Documentation says: J4A IIC port. Interface to BankSticks or to MBHP_IIC_* modules like MBHP_IIC_MIDI. J4B A second IIC port, which can also be used as an additional MIDI IN/OUT port (MIDI IN4/OUT4) if enabled in MIOS32 (add "#define MIOS32_UART_NUM 4" to the mios32_config.h file). MIDI IN4 will be available on the J4B.SC. If a 6N138 based optocoupler circuit should be connected, replace the 2.2k pull-up R10 by 1k, or add a second 2.2k in parallel to get 1.1k effectively. MIDI OUT4 will be available on the J4B.SD pin, it isn't required to remove R9 if already soldered - it doesn't hurt. So either J4A or if that one in use then you can use J4B. Edited March 10, 2014 by Shuriken
