I have a Op-1 synthesizer and I want to control it via USB with SEQV4.
http://www.teenageengineering.com/products/op-1
This synth have no midi output, only transmits midi on mini USB cable to your computer.
The solution are some midi interfaces like Kenton, iConnectmidi4+ or buy their expensive OP Lab for 400E :((
I bought a iConnectmidi2+ and because I didn't documented enough I realized that midi2+ don't work as a standalone device
without a host, and the OP-1 is not a host, only transmits midi on USB.
The ideea was to put the usb connector on the iConbnectmidi2+ and the midi in out cables on seqV4.
There is a way to make the connection directly on the USB connector from SEQ ?
I don't know how hard it is from the programmer view :smile: , it's standard midi data on usb cable ?, how seq see the external usb device etc..
Thank you. Maybe this will help other synthmaniacs with USB midi out synths.
Edited by strat-1
MBSEQ isn't a USB host device as well.
This could become a feature of the STM32F4 based "MIDIbox SEQ V4 Plus", but it has low priority at my side (because I know that this will result into some remote troubleshooting for devices which I don't own by myself)
