Shaeded Posted April 25, 2014 Report Posted April 25, 2014 Hello Community I wanted to know why the documentation of the LPC17 Core & AIN states: "For MIOS32 based applications, e.g. running on a MBHP_CORE_LPC17 module, please use MBHP_AINSER64!". Why? Is it a supply voltage issue? Will a AINX4 work on a LPC17? I want to scan a AINX4, but want to use the LPC17 for future upgrades. THX
Shaeded Posted April 27, 2014 Author Report Posted April 27, 2014 Ok I think i overlooked something. The LPC17 is limited to 8 AIN's in the design layout. knowing this it should be capable of running 8x 4051. Am i correct? I want to hook up 20 pots to the LPC17 and already have the PCB with 20 pots and 3x 4051 soldered, so the AINSER64 in not a option :no:. Will this work? THX
Shuriken Posted April 27, 2014 Report Posted April 27, 2014 I think you are misunderstanding. Without use of the MBHP_AINSER8 or MBHP_AINSER64, the max amount of pots is 8. So if you use the MBHP_AINSER you can do more.
Shaeded Posted April 27, 2014 Author Report Posted April 27, 2014 (edited) Hi Thanks for the feedback. I came up with this solution (PCB2), this should work right? Edited April 27, 2014 by Shaeded
Shuriken Posted April 27, 2014 Report Posted April 27, 2014 I did not check the complete schedule, but the concept looks good.
