Alasdair Moon Posted October 21, 2014 Posted October 21, 2014 (edited) Hi to all I am planning a sequencer to control both my normal synths and my analog modular system. Now that I've read some tons of documentation I wanted to ask for help, cause maybe I overlooked something or had other stuff not in mind first to my normal workflow : I work live and looped-based .. for me these are the two most important features ... none of my songs has several patterns or even a song arrangement ... everything goes via the tracks mute / unmute .. and of course I want my panel to be optimized for that If you look at the front panel attached I came up with the following stuff: It should be based on MBHP_CORE_STM32F4DISCOVER 2 Midi IO Modules to get 4 Midi IN and OUT 1 Quad IIC Midi Module for another 4 Midi Outs at least one .. maybe two AOUT_NG Module for up to 16 CV (powered by an external power source +12/-12/5) and a lot of DIN and DOUT (still have to calculate those) Question: how I take care of actually STM32F4DISCOVERY with current ?? Is this only via USB ?? The AOUT is powered by an external +12 / 12V / 5V PSU, can I connect the Board to that?? .. I read somewhere tet the STM32F4 is powered from 7V ?? the 16x4 BLM documentary says that I should use LEDs DUOCOLOR (so need three DOUT modules for the cathode and two anodes) ... Question: do I need dual-color LEDs at the GP LEDs too?? or is that obsolte then ?? Question 2: the documentary says I only need 2 more Shift Register for the button matrix ... how do I connect them ?? Gate Question: I need 5V Gates, so I should pass the gates through some 74HC541 .. I have seen a connection diagram somewhere but can't find it anymore :( Below you can see the panel layout ... Question: Do I still need the track button-row 1-4 or is thiat obsolete if I use the 16x4 BLM Matrix?? Suggestions welcome. love and light from Belgium, Sascha Edited October 22, 2014 by Ungleichklang
Alasdair Moon Posted October 21, 2014 Author Posted October 21, 2014 (edited) Update .. found that the STM32F4 can be powered by 5v ... Edited October 22, 2014 by Ungleichklang
