Phatline Posted December 3, 2014 Posted December 3, 2014 MIOS32Bit Core LPC17 © > following Code works: if(Potentiometer <= (rand() % 255)) { Gate = 0;} What the code does: The Potentiometer is a Variable > its a Analog Input: Value from 0-255 Gate is a Variable and it Gates a NOTE-STREAM. All Together its a Note-Random-Killer > with the Pot you set the change to be killed... MIOS 8Bit Core 18F452 © > it DOES NOT work, I got following Error: p --disable-warning 85 --obanksel=2 -I./src -I ./include/c -I ./include/share -DDEBUG_MODE=0 main.c -o _output/main.o main.c:224: warning 112: function 'rand' implicit declaration main.c:224: warning 84: 'auto' variable 'rand' may be used before initialization main.c:224: warning 84: 'auto' variable 'rand' may be used before initialization ./bin/mios-gpasm modifies _output/main.asm, result in _output/main__mios-gpasm-tmp.asm _output/main__mios-gpasm-tmp.asm:47:Error [113] Symbol not previously defined (_rand). _output/main__mios-gpasm-tmp.asm:694:Error [113] Symbol not previously defined (_rand). _output/main__mios-gpasm-tmp.asm:694:Error [113] Symbol not previously defined (_rand). make: *** [_output/main.o] Fehler 1 with the MIOS32 bit I dont had to declare nothing... The Quest now: how to program a random that has a predefinied min:0 & max:255 (I am not a C-Geek, Beginner > Detailed Answer would be great > "comparing 2 Registers in Cycles take the Result and..." > I cant perform such of that into code ;) (leider) (the first workaround and try of building an Analog Noise generator to feed into a AIN with an BC549 failed by smoking en up...) THANKS
Phatline Posted December 3, 2014 Author Posted December 3, 2014 ok got it... the search had results TK: 2006 tmp = random_seed_l * random_seed_h; random_seed_l = TMR0L + (unsigned char)(tmp & 0xff); random_seed_h = 0x69 + (unsigned char)(tmp >> 8); it makes random numbers from 0 - 255 all variables have to defied bevore of course...
