So, let's say I want to build the motor fader project and download the firmware for it, but then decide I also want to add encoder knobs as well for the 16E project. What firmware gets used then? It appears that both projects require the core to operate, but if I load the MF firmware, then how do I get the features of the 16E? Does that mean I need to add a second core to function as the 16E? What about using an LCD panel, does it require yet another core?
Each project requires their own core with their own firmware installed. So you would need two cores for a box with encoders and motor faders. Each core will support an optional LCD on their own.
Peace
Frank
Yes you require 2 cores one for the 16E and one for the Motor Faders.
The LCD is connected to the Core board by header plug so its possible to swap it round if needed.
In the future it should be possible (if we are really nice to Thorsten! ;)) to have 1 LCD to view multiple Core's data (via the MidiBox link purhaps?)
LO
