Led wiring
Marxon
Hi all!
I am a confused about the FM led wiring.
In the DOUT schematic the intrument and operator LEDs are connected to-SR2 D6 and SR D7.
It is not possible to change the pin configuration for these LEDs in „cs_menu_io_tables.inc“.
But here SR2 D6 and SR D7 are assinged to matrix Col1 Col2 instead.
Which configuration is correct?
Best regards
Marxon
Edited by Marxon
Link to comment
Share on other sites
Hi again!
It seems that the DOUT pins of the matrix get mirrored somehow.
In my Midibox FM i connected
LED column 1    SR 3    Pin 4
LED column 2    SR 3    Pin 5
LED column 3    SR 3    Pin 6
LED column 4    SR 3    Pin 7
LED column 5    SR 2    Pin 0
LED column 6    SR 2    Pin 1
LED row    1    SR 2    Pin 5
LED row    2    SR 2    Pin 4
LED row    3    SR 2    Pin 3
LED row    4    SR 2    Pin 2
but in cs_menu_io_tables.inc i have to define it:
DIO_M_TABLE
    ;; --> DIN <-- pins of the 6 column select buttons
    ;;         Col1 SR/Pin, Col2 SR/Pin,  Col3 SR/Pin,  Col4 SR/Pin,  Col5 SR/Pin,  Col6 SR/Pin
    DIO_M_COL_ENTRY  3, 6,        3, 5,         3, 4,         3, 0,         3, 1,         3, 2
    ;; --> DOUT <-- pins of the 6 LED columns
    DIO_M_COL_ENTRY  3, 3,        3, 2,         3, 1,         3, 0,         2, 7,         2, 6
    ;; --> 1*DIN/4*DOUT <-- pins of the 4 row select buttons
    ;;         DIN SR/Pin,  Row1 SR/Pin,  Row2 SR/Pin,  Row3 SR/Pin,  Row4 SR/Pin
    DIO_M_ROW_ENTRY  3, 3,        2, 2,         2, 3,         2, 4,         2, 5
Link to comment
This is related to the typical confusion about the pin order.
The first DOUT pin (offset 0) is D7, the next (offset 1) is D6, etc..
Documentation is much better in newer projects (e.g. in MIOS32 based projects I used "D7..D0" instead of offset "0..7")
Link to comment
Thank you Thorsten!
A friend has my first FM synth so i couldt not check how i wired it there.
I edited the cs_menu_io_tables.inc so that the pin order matches the "MIDIbox FM CS DOUT map" schematics.
(It is just a other pin calculation, so please do not laugh)
DIO_M_COL_ENTRY MACRO sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3, sr4, pin4, sr5, pin5
    db    ((7 - pin0) + 8*(sr0-1)), ((7 - pin1) + 8*(sr1-1)), ((7 - pin2) + 8*(sr2-1)), ((7 - pin3) + 8*(sr3-1)), ((7 - pin4) + 8*(sr4-1)), ((7 - pin5) + 8*(sr5-1))
    ENDM
DIO_M_ROW_ENTRY MACRO sr_in, pin_in, sr0, pin0, sr1, pin1, sr2, pin2, sr3, pin3
    db    ((7 - pin_in) + 8*(sr_in-1)), ((7 - pin0) + 8*(sr0-1)), ((7 - pin1) + 8*(sr1-1)), ((7 - pin2) + 8*(sr2-1)), ((7 - pin3) + 8*(sr3-1))
    ENDM
There is also a writing mistake about the CAN bus pins in the setup*.asm files:
    ;; if 1: pin RB2 and RB3 are used for CAN bus
    ;;       MBHP_OPL3 data pins #2 and #3 have to be connected to PIC pin RB1 and RB2
    ;;       (available at J5:A6 and J5:A7)
Correct is:
    ;;       MBHP_OPL3 data pins #2 and #3 have to be connected to PIC pin RE1 and RE2
Best regards
Marxon
Edited by Marxon
Link to comment
Guest
Reply to this topic...
