Selling my midibox seqV4
it is fully functioning, completly build and running the latest software....(you can always update via usb midi if there is a new software)
it is housed in a neatly finished acrillic lazercut case....the case is glued on the inside and very solid.... can be opened if needed)
Inside the case:
STM32F4 (newest core module...running latest software
Wilba CS (control surface)
Midi IO module
IIC midi module (so this box has a total of : 2X midi IN and 6X midi OUT)
SD-cardreader (with 8 gig SD-card)
Black on White wide angle LCD displays
it is USB powered (either from your computer or from a powered usb hub
i am selling this midibox sequencer (with or without the TPD module (track position display)
The TPD is connected with a cable to the midibox)
Price: with TPD 625 Euro
          without TPD 575 Euro
post-7943-0-79821300-1430903245_thumb.jp
post-7943-0-83397300-1430903310_thumb.jp
