electrodancer Posted May 6, 2015 Posted May 6, 2015 Selling my midibox seqV4 it is fully functioning, completly build and running the latest software....(you can always update via usb midi if there is a new software) it is housed in a neatly finished acrillic lazercut case....the case is glued on the inside and very solid.... can be opened if needed) Inside the case: STM32F4 (newest core module...running latest software Wilba CS (control surface) Midi IO module IIC midi module (so this box has a total of : 2X midi IN and 6X midi OUT) SD-cardreader (with 8 gig SD-card) Black on White wide angle LCD displays it is USB powered (either from your computer or from a powered usb hub i am selling this midibox sequencer (with or without the TPD module (track position display) The TPD is connected with a cable to the midibox) Price: with TPD 625 Euro without TPD 575 Euro
