eptheca Posted October 28, 2015 Posted October 28, 2015 I have SEQ V4 (STM32F4) with ilmenators BLM 16x4 and TPD.I want to add a DOUT Shift Register for gates.Should I connect this SR at the end of the chain, after the TPD?How should I write this in the config file MBSEQ_HW.V4 ?If Wilbas CS uses 2, the BLM 9 and the TPD 6, is SR 17 correct?If this is the place in the config file, what does "Allowed values: 1-16" mean?################################################## # CV and Gate/Trigger/Sync Setup ################################################## # AOUT interface now selected in CV Configuration Menu and stored in MBSEQ_CV.V4 file # please scroll through the menu to find this page! # additional gate triggers are available on common digital output pins of the # DOUT shift register chain - they are assigned to AOUT channel #16 (Note C-1, C#1, D-1, ...) # define the shift registers which should be used here (each provides 8 gates) # Note that SRs assigned to this function cannot be used as LED outputs (exclusive function) # Allowed values: 1-16, 0 disables the function, all other values invalid and not allowed DOUT_GATE_SR1 0 DOUT_GATE_SR2 0 DOUT_GATE_SR3 0 DOUT_GATE_SR4 0 DOUT_GATE_SR5 0 DOUT_GATE_SR6 0 DOUT_GATE_SR7 0 DOUT_GATE_SR8 0 # if set to 1, the DOUT "gates" will send 1mS pulses # useful for analog drums DOUT_1MS_TRIGGER 0Cheers, Hal
TK. Posted October 29, 2015 Posted October 29, 2015 Your configuration is outdated, please find valid information in the hwcfg/wilba_tpd/MBSEQ_HW.V4 file which is part of the release package.There you will find a new parameter which allows to enable more SRIOs:# maximum number of connected shift registers in a DIN or DOUT chain (1..23) SRIO_NUM_SR 23and you will find an update in the comments which refer to valid SR rangesBest Regards, Thorsten.
