monokinetic Posted April 6, 2017 Report Share Posted April 6, 2017 I know you mentioned the testaoutpin to check connections, but have you tried caliaout? That might be worth a try when the Seq app is running, you can measure the exact voltages on each output. Otherwise could you provide details on the type of track etc that you are configuring in MBSeq to try and test your AOUT_NG? Is it a note track, what is the output set to, and so on. Good luck Quote Link to comment Share on other sites More sharing options...
slo Posted April 7, 2017 Author Report Share Posted April 7, 2017 Tested caliaout on MB_NG in the MIOS terminal and obtained the expected results, all voltages close to the inputted caliaout values on channel #1, min, mid, max, 1v, 2v, 4v, 8v. However when tested on SEQV4 app no output, meter stays at min value .008v. I usually go straight to CV Configuration to try to setup the Aout_NG, I have tried a 4 note (C3) loop on a track with output set as Aout CH#1, then init the track, with this running I can see CV_Gate action, but no CV. Quote Link to comment Share on other sites More sharing options...
Alasdair Moon Posted October 10, 2017 Report Share Posted October 10, 2017 I seem to have the same problem with my AOUT_NG and SeqV4 ... I will do some more testing and direct connection to J19 as proposed ... Quote Link to comment Share on other sites More sharing options...
