ansolas Posted December 16, 2015 Posted December 16, 2015 (edited) Hi, is it possible to create a controller with encoders which has the following behavior: if you turn slow it is as precise (as a 1024 step Motor Fader) as using a mouse (perfect to tweak EQ's or 'tune' a Filter ) if you turn faster it increments faster It should be highly responsive to direction changes (play the filter as a analog synth) It would be awesome if you could enable easing functions such as: https://jqueryui.com/resources/demos/effect/easing.html Possible ? Edited December 16, 2015 by ansolas
TK. Posted December 16, 2015 Posted December 16, 2015 I guess that you mean something like the Arc: http://createdigitalmusic.com/2011/01/arc-a-new-design-from-monome-creator-after-grids-encoders/ Such highres encoders are unfortunately not supported by the MIDIbox platform Best Regards, Thorsten.
ansolas Posted December 16, 2015 Author Posted December 16, 2015 (edited) Thank you for your reply ! anything else ? This article is quite old and just theory ? Is there any high resolution controller out there which is more precise than anything from novation ? Edited December 16, 2015 by ansolas
ansolas Posted December 21, 2015 Author Posted December 21, 2015 (edited) I just found this project : http://www.96khz.org/htm/midicontroller15spdif.htm Edited December 21, 2015 by ansolas
Shuriken Posted December 21, 2015 Posted December 21, 2015 Ok, just hook up that FPGA to a midibox controller and we are good to go
TK. Posted December 21, 2015 Posted December 21, 2015 No FPGA is required to scan highres encoders, this can also be done with a MIDIbox NG. It features USB MIDI which ensures fast transfer of highres (NRPN) values, I don't see the need for using the SPDIF interface for this purpose as explained at the 96khz.org page (I think that the information at this page is a bit outdated). The biggest problem is the price of such encoders (starting at ca. 40 EUR), therefore I never tried this by myself... But maybe we just misunderstood Ansolas? Typical encoders cost around 1..2 EUR, they provide 24 detents per revolution, but by using accelleration algorithms, editing higher resolution values (e.g. 14 bit NRPN) can still be handled. And this is exactly what MIDIbox NG is doing. Once you need a higher accuracy (such as 96 detents per revolution), you come into the 50 EUR range. Is this the class of encoders you are searching for? Best Regards, Thorsten.
ansolas Posted December 22, 2015 Author Posted December 22, 2015 Thank you for your replys, essentially I don't care bout which encoders :) I just want an accurate controller Such kind of accelerating functions would be interesting, they would let do use some "rubberband" automation things :) Anything that is more accurate as a Novation SL mkII Control should be enough.
TK. Posted December 22, 2015 Posted December 22, 2015 Ok, in this case just build a MIDIbox NG: http://www.ucapps.de/midibox_ng.html This page also links to a user manual - please read to get a better overview before asking the next questions ;) You need one MBHP_CORE_STM32F4 module and one MBHP_DINX4 module (for up to 16 rotary encoders - purchase more DIN boards of you want to connect more encoders...) This configuration file shows different kind of speed configurations: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fencspeed.ngc It works with up to 14bit resolution (just change the range and send NRPN events) Speed could also be varied by pressing a button as shown in this more complex example: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fmidibox_ng_v1%2Fcfg%2Ftests%2Fencbanks.ngc Best Regards, Thorsten.
