mongrol Posted January 22, 2016 Posted January 22, 2016 Hi folks, In the Wilba BOM docs there is this sentence. Quote The TL-1240 are short (8.2mm) so they cannot be used with encoders installed but are wired correctly for the LEDs. Can someone tell me what the actually means? I understand they are 8.2mm (seems small) and that the gap (10mm) and panel (3mm) means they would actually be below the panel surface. How would this work? Does this mean you can't actually install the encoders at all in order to bring the 10mm gap down?
