Smithy Posted January 25, 2016 Report Posted January 25, 2016 (edited) So in the Wavetable Sounds Tutorial #1 Page for MIDIbox SID V1, there is this jsynthlib screenshot: This makes sense to me, it shows 2 different Parameters starting at Step 00. However if I try to do it on MBSID V2, it duplicates the values for both parameters: If I increase the value for Parameter one (Column 2) it also increases the value for parameter 2 (Column 3). Rutgers Editor also only allows one value to be entered. This seems to be the same in both the Lead and Multi Engine. Is there a way of entering seperate values for each parameter, when they both start at step 00? Thanks. Edited January 26, 2016 by Smithy Quote
Hawkeye Posted January 26, 2016 Report Posted January 26, 2016 Welcome back, Smithy, how is Ireland? ;-) Wild guess: WT1 BEG = WT 2 BEG, so both views map to the same memory byte, modifying one will also modify the other. Redemption: set WT2 BEG to a different value! :-) Many greets, Peter Quote
Smithy Posted January 26, 2016 Author Report Posted January 26, 2016 (edited) Thanks Hawkeye! U R GOOD FRIEND! Rutgers Editor confused my understanding of the Wavetable Sequence: I thought the knobs "Start Pos" and "End Pos" related to the Steps of the sequence. But as Hawkeye explained they are Memory Addresses hence the $ sign. TK Y U NEED 2 B PROGRAMMAR TO PLAY MBSID! U R BAD FRIEND! ;) Just kidding, you are awesome friend. Edited January 26, 2016 by Smithy 1 Quote
