doc007 Posted April 16, 2016 Posted April 16, 2016 Hello Friends, My Midibox SEQ V4 is finished and works really well . I have a question regarding one midi output. I have a question regarding the midi output. Can I connect any midi output without using a synthesizer to an analog amplifier using the module AOUT_NG or another DAC ? Pierre
latigid on Posted April 16, 2016 Posted April 16, 2016 Do you mean you want to assign a track to an AOUT port? This would be done by setting up the track on the AOUT channel of your choice. You can also route a MIDI input to an AOUT port just like a MIDI-CV converter. Or do you mean something else? It's not so clear from your question.
doc007 Posted April 16, 2016 Author Posted April 16, 2016 2 hours ago, latigid on said: Do you mean you want to assign a track to an AOUT port? This would be done by setting up the track on the AOUT channel of your choice. You can also route a MIDI input to an AOUT port just like a MIDI-CV converter. Thank you for the answer Pierre
