Psykhaze Posted April 22, 2016 Posted April 22, 2016 Hi there ! A simple question with maybe a complicated answer: - Is there a simple way to drive rgb LEDs , to make a multicolor BLM ? From what i understood DOUT module only provides ON/OFF outputs and AOUT module seems to be more designed to drive old analogic synths than LED. Thanks in advance for your answers , this subject may have already been covered but i did not found the answer simply. regards, JK
latigid on Posted April 22, 2016 Posted April 22, 2016 DOUT can also provide a type of PWM, but it only works well when the LEDs are addressed individually (i.e. not in a matrix). Which means quite a lot of DOUT pins. A better method is to use WS2812 LEDs which respond to a serial data chain. See the end of that thread for working layouts with 4*4 Sparkfun button pads and illuminated encoders.
Psykhaze Posted April 22, 2016 Author Posted April 22, 2016 Thanks for the quick answer , i'll have a check on it. Good evening, regards, JK
