Psykhaze Posted April 28, 2016 Report Posted April 28, 2016 In order to build matrix driven additive / substractive post-mix module, (for blending synth output modules) Would someone advice me a good drivable op-amp that could achieve Mixing , Filtering and Amp functions? Few audio circuits detailed Here Principle of additive/substractive synthesis in the pic below. Greets, JK
Sauraen Posted April 29, 2016 Report Posted April 29, 2016 How many projects are you trying to do at once?! I use TL072/TL074 as my go-to op-amp for audio applications when a bipolar supply is available, and MCP6002/MCP6004 for +5V only. Any op-amp can do mixing, filtering, and amplifying; the characteristics that distinguish op-amps are more based on the overall application (audio, which determines the frequency range) and the supply voltage, rather than whether you're doing filtering or mixing.
Psykhaze Posted April 29, 2016 Author Report Posted April 29, 2016 That is just a design concept/question =) I have much work with MBFMX2 and will stick to it before anything else ^^ Did not said i will realize anything in this way. Just had this idea of a "post-mixing" module , something that could help mixing synth modules outputs in a funny way. And remembered about additive/substractive modulation matrixes. Then you have this thread :D Regards, JK
Psykhaze Posted May 2, 2016 Author Report Posted May 2, 2016 Found kind a reply here http://wiki.midibox.org/doku.php?id=midibox_audiomatrix
Psykhaze Posted May 5, 2016 Author Report Posted May 5, 2016 @Sauraen After documenting a bit more , i've learnt about crosspoint switches. Found this crosspoint switch in DIP package Link to the CP switch (CD22M3494) This CP switch could be driven by a dout ? So , as well as MCP600X OP-Amp looks fitted to audio apps and works in 5V, I think a nice postmixing design could be done based upon this CD22M3494 switch and 2/4 MCP6004? thanks in advance for your answer, Best regards, JK
Sauraen Posted May 6, 2016 Report Posted May 6, 2016 That looks like an interesting chip, though I'm not sure what you need a 16x8 matrix for. Yes, the digital inputs could be driven by a DOUT plus an additional line for Strobe (clock).
Psykhaze Posted May 6, 2016 Author Report Posted May 6, 2016 I admit 16x8 may sound big,. But what can do most can do less ? And this chip is DIP, that's kinda difficult to find CP switches in this DIY-friendly format working with 5v. Matrix would allow to make like some "patching fun" by routing the signals in different inputs/outputs, driven by core. On some matrix outputs you could have some traditional filter design like HP/LP/BP and on other one outputs some mixing setups. Plug your audio synth modules outputs to this and reroute/filter your signals in the funny ways you want, that was the "concept". If you think this chip may sound ok, i could start a raw design upon this. (Still making my mouser order list, think will order one of these CP switches to experiment on the protoboard =) ) Thanks for answering, Best regards , JK
Hawkeye Posted May 6, 2016 Report Posted May 6, 2016 Nice chip! If it is good enough for video signal switching, it should be easily able to cope with audio signals... :-) Please keep us posted on that project... An affordable, standalone MIDI-controlled audio switcher surely is a nice thing - I know, there have been similar mixer projects before, but this looks like a fairly simple and affordable solution... Everybody, who does not have enough mixer ports and hates switching with good old patchbay cables or needs a kind of "total recall" for patchbay wiring would benefit. Many greets! Peter
Psykhaze Posted July 12, 2016 Author Report Posted July 12, 2016 (edited) In the end will be integrated in http://wiki.midibox.org/doku.php?id=mb-modulbox-ng project, module 21. Bests, JK Edited July 13, 2016 by Psykhaze
