hi
does anyone noticed on synths (like Korg MS - 2000) there are led named original value.
with midibox the problem is that when you work in a program and you got the values right and sound good, then you minimized it and opened a synth, sipn a few knobs and return to the original prog with your precious song, move just a little filter cutoff and the position jump and wrecks your song. (this is the pot you spun in the synth)
can it be somehow avoided?
put on an original value led so it shows how it was?
thankyou.
P.S. if someone did not understood my explanation please ask.
thankx Thorsten
part of my concern has dissapered but can i make an led that shows original value whilist i'm in the program (showing what the saved value is) or at least say that snap mode is on and the position is reached?
thanx
encoders...expencive...2.00 pounds x 40... no thank you!!
Sure, you can do this, just 5 lines of code - but the already available implementation which shows an arrow on the screen is much more useful in my eyes - with the arrow you know in which direction the pot has to be turned to reach the initial value.
