hi,
Recently I bought a JX-8P and decided to program it with a nice looking MidiboxPlus ( no matter the age :))
I am using:
16F877-20/P
20 MHz xtal
mplus_pcb_v1.brd  redesigned board which is consistent with the final schematic
succesfully burned and verified  PIC with ME-Prog from Micro Engineering using Epic Programmer ( I made a lot of Midibox with this programmer )
midibox_plus_v1910.zip  is the firmware with the 16 pot variant
now the pain
I powered up about 50 or 60 times and LCD visualized the right screen only 3 times. ( as you can see in the attached image )
the other times a line of blank character .
It seems to me something like a bad LCD initializing ( am going to buy another LCD in the case the one I have may be too slow)
Please does anyone reported  strange behaviour like this on MidiboxPlus or other possible cause of malfunction? ( I am searching in the forum but have not a solution yet )
Thanks for any help or information
Best regards
Antonio
P.S.
I am going to buy new LCD from different manufacturers but if someone reported of slow LCD ( initializing ) please I will be glad for any help
Edited by Antix
Information adding
  • 3 weeks later...
Do other readers: MIDIbox Plus is not a MIOS based firmware.
This information is only relevant for PIC16F based designs that I published ca. 13 years ago
@Anitix: could you please check if the power-up timer is enabled?
-> http://microchip.wikidot.com/8bit:pwrt
Without this timer it could be that the display initialisation starts too early for your LCD
Thanks Thorsten for your reply
as usual you are very kind
Often the more you break your head on the wall the more simple is the solution of the problem
After a lot of evening trying to make work my circuit I noticed that the problem is the programmer and the 16F series.
I made a lot of midiboxes with my programmer without any problem but 16F877 wants Vdd during programming
and as you can see in the schematic the "P" ( programming ) position cuts  Vdd. ( the "E" position is for evaluation board function )
With Pic 18F452 or 4620 or 4685 I never had this problem an succesfully programmed in P position
Probably I am a stupid and forgive me if all of you already knows that 877 needs Vdd during the programming but may be useful share this information about older PIC.
I was deceived from the random operation , as you can see the picture the circuit worked occasionally.
Thanks again to TK
Best regards
Antonio
Edited by Antix
