julianf Posted May 17, 2017 Report Posted May 17, 2017 Ive been cutting some buchla panels recently, so i thought i would use some of the material that i purchased for them to cut a couple of mb6582 panel sets. This is the material, and the infill colour - Ill see if i cant take a photo of the mb6582s later, but, i think, they look pretty nice - just something a bit different from the usual black with white text! Thank you, Julian
julianf Posted June 16, 2017 Author Report Posted June 16, 2017 Just gotten around to taking a photo of this - Its a nice finish - probably nicer than the photo really shows. Ill see if i cant take another photo of it mounted to one of the pactec cases. Note - this material is brushed AND anodised. The anodising means that it wont stain or scratch easily, like normal brushed does.
Rowan Posted June 16, 2017 Report Posted June 16, 2017 Any chance of cutting a MB-SEQ set in with this material?
julianf Posted June 16, 2017 Author Report Posted June 16, 2017 In what format? I ask, as it only comes up to 1.5mm, so would be no good for 19" units.
Rowan Posted June 16, 2017 Report Posted June 16, 2017 In the same format that you currently do for the MB-SEQ panels, just a change of material.
julianf Posted June 16, 2017 Author Report Posted June 16, 2017 I cut at least three different formats. The panel will work with the first and the last (both 17"), but it will be too thin for the 19".
