macsaif Posted December 14, 2017 Report Share Posted December 14, 2017 Hello, I am building a 2 manual controller. I am using for upper manual a 61key Fater TP/8O and for the lower manual a 73 key Fatar TP/8O (on that manual the diodes are inverted-I had to do it because I have used it with a Roland controller board which had an inverted logic than the standard Fatar). My questions regarding the Midibox KB: 1.Is it possible to reconfigure the controller during play (not at initializing) for example by activating/deactivating an input of the board: - configure to which output channel I am sending info from which manual (1, 2, 3, 4 or 1+4) - cinfigure low trigger mode separately for each manual (when I play organ sounds) - Adjust octaves +/- 1-2octaves - Configure pitch bend and modulation wheel - to which midi channel they are sending data (1 or 4, or both) - Configure sustain switch and expression pedal in - to which midi channel they are sending data (1 or 4, or both) 2. How do I have to wire the connectors on the keybed with inverted diodes? - or it os better to resolder the diodes Thank you Frank Quote Link to comment Share on other sites More sharing options...
