Hello,
I try to make a Dj controller with midibox NG. I try to make a 2 decks with possibility to control 4 decks. I can control the 4 decks with 2 button per side (deck 1-3 and deck 2-4) the problem is when I start the controller (with or without a dj software), the right deck is not active (I need to push the deck 2 or 4 button to activate it and be able to contol it).
so how can I have the left and right decks active in the same time?
I join my basic .NGC
thanks
DEFAULT.NGC
  • 2 weeks later...
Posted (edited)
Hello
I just have a quick look at your ngc (hard to read without text reformatting...)
You have some led fwd without led definition
also multiple event (same hw_id) with same id
For your problem what I suspect is that your button 23/24 have a radio group (2) with respectively range 3 and 4,
there is chance that at start the radio group 2 will have value 1 by default.
Maybe just try value=3 at EVENT_BUTTON    id=502    hw_id=23
Best
Zam
Edited by Zam
hi,
tried your suggestion, but no success. I tried different values too with same result. I thought 'bank' was a simple way to control a deck ( define a bank and put all its control in) but maybe its not the best way
  • 2 weeks later...
