goyousalukis Posted January 22, 2018 Report Posted January 22, 2018 Hey Guys, I went ahead and ordered the control panel PCB from Modular Addicts, along with the assorted encoders, etc from Mouser/Amazon. I have an old Midibox Sid, and I am upgrading to V2. I have the new PIC on the way. My MBSid only has 2 Sids. The website didn't have a photo of the back of the PCB. I assume I can just hook my existing Core and 2 SIDs up to the control panel. Is this correct? Also, is there a DXF of the panel somewhere? I have a CNC and Laser engraver, so I want to cut my own panel. At some point, I might go whole hog and purchase the 8 sid main board. Thanks, Justin
goyousalukis Posted January 22, 2018 Author Report Posted January 22, 2018 Sorry for the multiple posts - it wasn't showing up. I can't find a way to delete it. If an Admin can delete, please do.
Hawkeye Posted January 23, 2018 Report Posted January 23, 2018 No problem, i've deleted the other thread. Regarding your question, maybe it would be easiest to just start building the MB6582 baseboard (and e.g. populate it with a single core and two SIDs first) - it connects easily to the MB6582 control surface and all is well documented. As you were already thinking of going that way, i'd recommend to just do it. The MB6582 baseboard needs not be fully populated with PICs and SIDs, you can just start with a single core and a SID pair. Many greets, Peter
goyousalukis Posted January 23, 2018 Author Report Posted January 23, 2018 Thanks Hawkeye - can you point me to the documentation? I've had a look around, but haven't found it.
Hawkeye Posted January 23, 2018 Report Posted January 23, 2018 No problem, here: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582 especially here for the baseboard: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582_base_pcb_construction_guide and maybe this one for the control surface :) Have fun! Peter
goyousalukis Posted January 23, 2018 Author Report Posted January 23, 2018 Thanks so much Peter, I now have hours of entertainment while I wait for the parts to arrive. That build guide looks great - thanks for all your efforts!
