Is there any way to transmit C -2 note? It seems to stop at C -2#.
I am working how best to use the Digitakt as a sound module and just discovered in a very low octave it will trigger sounds from one midi channel (rather than each track using it's own midi channel). Unfortunately, Track one on the Digitakt needs C-2 note and he Seq v4 finished one semi tones higher.
Unfortunately c-2 (note value #0) is consequently used at many places to disable the note (no MIDI event will be sent)
The only workaround I could imagine is a private firmware modification which transforms a particular note to c-2
