WingMa Posted March 22, 2018 Posted March 22, 2018 Does anytime on ucapps.de dinx4_v1??? i have only dinx4.brd no version! Does any important different between v1 and v2
goyousalukis Posted March 22, 2018 Posted March 22, 2018 (edited) Hi, I don't quite understand your question, but I will give it a shot. There are two main versions of the DIN board. The newer version has 4 10 Pin Headers - each has 8 inputs available. Here is the schematic: http://ucapps.de/mbhp/mbhp_dinx4_r5.pdf The older version has 8 5 pin headers - each header has 4 inputs available. Here is the schematic: http://ucapps.de/mbhp/mbhp_dinx4.pdf Functionally, there is no difference between the two designs - they can be interchanged. The newer one is better because it is easier to quickly make a 10 conductor cable with ribbon cable and IDC sockets/headers, versus crimping Molex connectors on the 5 pin version. Hopefully this helps a bit... Justin (EDIT) Another change between the two is that the newer version has the ability to use the resistor array instead of individual resistors. Edited March 22, 2018 by goyousalukis
goyousalukis Posted March 22, 2018 Posted March 22, 2018 Also, I have old DIN/DOUT boards that I made back in 2002 that I am using with my new MB Sequencer V4 (STM32F4 Core) with no issues, and no changes.
WingMa Posted March 22, 2018 Author Posted March 22, 2018 (edited) Thank you! I manufactured the board about 2009 but now I need other and a didn’t know the original printings are ok or I need to do absolutely new! The old file name is dinx4.brd I didn’t know wich version I have a prints Edited March 22, 2018 by WingMa
WingMa Posted March 22, 2018 Author Posted March 22, 2018 If you are here maybe can help me! The ucapps has a pdf about button 8x16 use one dout board to! Can I extended 8x32 button?
WingMa Posted March 22, 2018 Author Posted March 22, 2018 Or one dout board j3 goes to 8x32 button and other 3 j connector to 8x16 led?
goyousalukis Posted March 22, 2018 Posted March 22, 2018 Is this what you need? http://www.ucapps.de/midio128/midio128_v3_scanmatrix.pdf
