tago Posted September 16, 2019 Report Posted September 16, 2019 Hi. I want to implement octave up/down buttons as found on many midi keyboards. I've read the NGR documentation and can't find a way to either read the value of kb_transpose or declare a global custom variable instead. The custom var would be used to store the current transpose value and in if-else statements inside the NGR script. Do i have to setup a dummy element and use its value as my custom variable? If yes, how do i do this? Or is there a better way of doing this?
TK. Posted September 16, 2019 Report Posted September 16, 2019 Hi, there is currently no way to declare custom variables, but you can use the storage of any unused event instead. E.g. let's say you don't use LED:1000, then just use it to store your value. Best Regards, Thorsten.
tago Posted September 16, 2019 Author Report Posted September 16, 2019 (edited) Thank you Thorsten! May i ask how i can call another section from inside a section. if ^section == 1 RunSection:2 endif if ^section == 2 endif Edit: Sorry, just found it myself. exec_meta does the trick Edited September 16, 2019 by tago
TK. Posted September 16, 2019 Report Posted September 16, 2019 In this particular case you could also "set ^section 2", it should do the same (because ^section 2 follows ^section 1, no jump required) Best Regards, Thorsten.
tago Posted September 16, 2019 Author Report Posted September 16, 2019 (edited) Works too, thanks. I've a question regarding the range of kb_transpose. I'm planning to have a transposition range of +/- 2 octaves. I assume kb_transpose stepping is laid out in half tones, so it would look like -24, -12, 0, 12, 24. But this will not work as negative values seem to be forbidden. Any idea how to achieve this? Edited September 16, 2019 by tago
TK. Posted September 17, 2019 Report Posted September 17, 2019 Fortunately no problem to support negative values :) Please try this version: http://www.ucapps.de/mios32/midibox_ng_v1_037_pre5.zip Best Regards, Thorsten.
tago Posted September 17, 2019 Author Report Posted September 17, 2019 Very nice, thanks again. Will give it a try.
