macsaif Posted September 23, 2019 Posted September 23, 2019 Hello, I am trying to understand the parallax mode of AINSER. I would like to use it, but in my case it works exactly as DIRECT function. In NGC I am configuring the AINSER and the forwarded 2 SENDERs: AINSER n=1 enabled=1 muxed=1 cs=1 resolution=7bit pinrange=3:10:4055 EVENT_AINSER id=3 hw_id=3 fwd_id=SENDER:3 range=0:127 no_dump=1 ain_mode= Snap EVENT_SENDER id=3 hw_id=3 type=CC chn=1 cc=43 range=0:127 no_dump=0 ports=1111110000000000 EVENT_SENDER id=103 hw_id=3 type=CC chn=4 cc=43 range=0:127 no_dump=0 ports=1111110000000000 Based on the actual status of one button in .NGR I am activating Sender 3 or Sender 103 and copying its value back to AINSER. It works correctly with SNAP function but if I change the SNAP to Parallax it jumps directly to the actual status of the potentiometer when I move with it (like the direct mode). Can it be connected with the think that the AINSER works in range 0-4065 and the CC works in range 0-127? What is a correct solution? Frank
macsaif Posted October 2, 2019 Author Posted October 2, 2019 Nobody uses the Ainser in Parallax mode eith succes?
