flyweight Posted December 16, 2019 Posted December 16, 2019 Hi I tried and found the the midibox metronome. Would be very usefull for livesets using drums. I also found some discussion about the audio dac being able to output the metronome in audio. Is this feature available and how do you enable it? Thanks in advance, Tim
TK. Posted December 16, 2019 Posted December 16, 2019 Hi Tim, there is a metronome function which sends MIDI Notes, by default C#1 on Beat and Measure to Channel #10 of the default port (a GM compatible sound module would output the typical metronome sound). This can be configured at the Options page under 17/33 I think that this is sufficient. By enabling the Audio DAC, MBSEQ would be unnecessarily (over)loaded by outputting the wavestream. There is also not enough RAM available for such a feature (the remaining RAM should be saved for future features) Best Regards, Thorsten.
flyweight Posted December 22, 2019 Author Posted December 22, 2019 Hi Thorsten, Thanks for the reply. Fully understand. Still great that the metronome is there. Cheers Tim
