Hello!
Is it possible to "queue" a transpose so that it only triggers when the pattern restarts (goes back to step 1)?
You should probably read the manual once again. In your case, look for the first 3 options in the options page, which allow you to specify a number of steps before a pattern will be switched, on a per-session basis.
