Quote
This one is especially useful in conjunction with EVENT_RECEIVER for converting or just 1:1 forwarding incoming MIDI event values.
I'm trying to code a simple switcher in NG and find myself stuck. 4 buttons just select a synth on a channel, but I can't find the Event_Sender setting that will allow all midi events to pass through as stated in the .NGC document.
#attempt to make a small synth switcher
RESET_HW
LCD "%C@(1:1:1)vo.B vo.K  iPad syn4"
#setup encoder
ENC n=  1   sr= 1 pins=7:6   type=detented3
#disable router nodes
ROUTER n= 1   src_port=IN1   src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n= 2   src_port=IN1   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 3   src_port=IN1   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n= 4   src_port=IN2   src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n= 5   src_port=IN2   src_chn=0   dst_port=OUT4  dst_chn=0
ROUTER n=10   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=11   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=12   src_port=SPI4  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=13   src_port=USB1  src_chn=0   dst_port=OUT1  dst_chn=0
ROUTER n=14   src_port=USB1  src_chn=0   dst_port=OUT2  dst_chn=0
ROUTER n=15   src_port=USB1  src_chn=0   dst_port=OUT3  dst_chn=0
ROUTER n=16   src_port=USB1  src_chn=0   dst_port=OUT4  dst_chn=0
#get midi events from port USB1
EVENT_RECEIVER id=1  fwd_id=SENDER:1 type=NoteOn chn=1  key=any  ports=1000000000000000
#trigger different sections
EVENT_BUTTON id=5 hw_id=5  radio_group=1 button_mode=Toggle range=1:1 value= 1 label="@(1:1:2)  *    o     o    o "
EVENT_BUTTON id=6 hw_id=6  radio_group=1 button_mode=Toggle range=2:2 value= 0 label="@(1:1:2)  o    *     o    o "
EVENT_BUTTON id=3 hw_id=3  radio_group=1 button_mode=Toggle range=3:3 value= 0 label="@(1:1:2)  o    o     *    o "
EVENT_BUTTON id=4 hw_id=4  radio_group=1 button_mode=Toggle range=4:4 value= 0 label="@(1:1:2)  o    o     o    * "
#send midi events to port usb1 if button  pressed
EVENT_SENDER  id=1 if_equal=Button:5:1  type=NoteOn chn=1   key=any  ports=1000000000000000
EVENT_SENDER  id=1 if_equal=Button:6:2  type=NoteOn chn=2   key=any  ports=1000000000000000
EVENT_SENDER  id=1 if_equal=Button:3:3  type=NoteOn chn=3   key=any  ports=1000000000000000
EVENT_SENDER  id=1 if_equal=Button:4:4  type=NoteOn chn=4   key=any  ports=1000000000000000
This is my staring point. It works but the type=NoteOn parameter in the EVENT_SENDER line needs replacing with something to allow all midi events to pass. I'm sure I'm missing something simple here
