intosite Posted January 21, 2004 Posted January 21, 2004 ???Need some help. Also under the model has these no, 03521UM on the 18F452 and 035054K on the 18LF452...Cheers
Scuzzle Posted January 21, 2004 Posted January 21, 2004 The 18F452 is the one the you want.The 18LF452 is the Low Voltage version of the chip and not the one used in the Midibox. After having a quick look at the datasheet I'm not 100% sure if the LF model will work or not, although I'd tend towards that it will.Maybe someone else can comment on its usability...
Captain_Hastings Posted January 21, 2004 Posted January 21, 2004 PIC18LF452-I/P works as well, i have one core running with it.cheers
TK. Posted January 22, 2004 Posted January 22, 2004 me too - both are working fineBest Regards, Thorsten
intosite Posted January 22, 2004 Author Posted January 22, 2004 okie.. cool.. so technically you can get up to 6 free sample chips from microchip that you can use for the midi box...
