Hi all,
I built the USB module and tried to install the EZ-USB driver on my Windows XP pro system.
It didn't work; the installation routine kept telling me that there was a faulty line in the ezusbw2k.inf file.  >:(
Obviously many users of the USB module are experiencing this problem.
After searching the forum without satisfactory result I began parsing through the .inf file to find the error, and -at last!- I found a solution.  ;D
It seems that the ezusbw2k.inf fails to copy the ezmon.sys and ezusb.sys files into the proper directory.  ???
Solution:
just copy ezmon.sys and ezusb.sys into the C:\WINDOWS\system32\drivers directory by hand, install the driver again and there you go....  8)
have fun
regards, SB
Hi SB,
thank you very much for this really simple solution!!! :-)
I've added a note to the README.txt
