Im planning on building a SID module  :D using the current PCB layout, what would be the chance that the design would change once the 18F is used or can I presume the same board will work? (just swap the 16F change the voltage and a couple of components?)
T.I.A.
LO
no, everything is 1:1 hardware compatible, no parts beside of the PIC have to be exchanged.
I'm only unsure if the JDM module can be reused (still waiting for inputs ;))
