Stupid programming question :)
Hi!
I was gonna test the nokia lcd option on my box... problem is; i don't know how to integrate the  custom lcd driver onto the midibox application.
OK... i see a main.syx file on the custom driver directory... if i understand it right, all i have to do is upload this file... is that correct?
besides that problem, i think i can handle the rest of the modifications on the code
Hope someone can help me :)
Thanks,
Ryan ---> stupid hehe :)
no - it isn't possible to run multiple applications at the same time.
Therefore you have to copy the app_lcd.inc driver into the application directory, and you have to change the LCD type in the USER_Init function of the application you are using (example can be found in app_init.inc of the driver package).
Once this has been done, you have to rebuild the application and convert it to a .syx file
FAQMARKER
Thanks TK!
I seem to ask a lot of "frequently asked questions":)
Thanks!
Ryan
midibox64_v2_2 has no app_init.inc do i have to copy that too?
User_init is found on main.asm but nothing below it pertains to the custom lcd driver
Lost again... help! please...
Thanks Ryan
Just add the code of app_init.inc to the USER_Init of the midibox64 application. Don't replace it, otherwise the application won't run correctly!
ok... just make sure i got it... i have to replace the app_lcd.inc on the midibox app directory withe the app_lcd.inc from the driver package then add the code of app_init.inc under User_Init  on the main.asm file on the midibox app directory... right? sorry if being such a pain in the ass:)
Much Thanks!
Ryan
