Guest Ryan Posted February 21, 2004 Posted February 21, 2004 Hi! I was gonna test the nokia lcd option on my box... problem is; i don't know how to integrate the custom lcd driver onto the midibox application.OK... i see a main.syx file on the custom driver directory... if i understand it right, all i have to do is upload this file... is that correct? besides that problem, i think i can handle the rest of the modifications on the codeHope someone can help me :)Thanks, Ryan ---> stupid hehe :)
TK. Posted February 21, 2004 Posted February 21, 2004 Hi,no - it isn't possible to run multiple applications at the same time.Therefore you have to copy the app_lcd.inc driver into the application directory, and you have to change the LCD type in the USER_Init function of the application you are using (example can be found in app_init.inc of the driver package).Once this has been done, you have to rebuild the application and convert it to a .syx fileBest Regards, Thorsten.FAQMARKER
Guest Ryan Posted February 22, 2004 Posted February 22, 2004 Thanks TK!I seem to ask a lot of "frequently asked questions":)Thanks!Ryan
Guest Ryan Posted February 22, 2004 Posted February 22, 2004 midibox64_v2_2 has no app_init.inc do i have to copy that too? User_init is found on main.asm but nothing below it pertains to the custom lcd driverLost again... help! please...Thanks Ryan
TK. Posted February 22, 2004 Posted February 22, 2004 Just add the code of app_init.inc to the USER_Init of the midibox64 application. Don't replace it, otherwise the application won't run correctly!Best Regards, Thorsten.
Guest Ryan Posted February 22, 2004 Posted February 22, 2004 ok... just make sure i got it... i have to replace the app_lcd.inc on the midibox app directory withe the app_lcd.inc from the driver package then add the code of app_init.inc under User_Init on the main.asm file on the midibox app directory... right? sorry if being such a pain in the ass:)Much Thanks!Ryan
TK. Posted February 23, 2004 Posted February 23, 2004 You're on the right way :)Best Regards, Thorsten
