Guest Simeon Posted November 18, 2002 Posted November 18, 2002 Hello,Due to a design change in my midibox I have 6 of thePanasonic motor faders left. Â These were never used.Here is what I have:6 Panasonic Motorfaders @ $7.00 42.006 TC4427 FET controllers 9.781 74595 .7815 10k ohm resistors .8415 1N4148 switching diodes 1.8024 1N5418 Schotky Diodes 3.7710 .010 uf ceramic Capacitors 1.08Total Parts: $60.05 USShipping: (Sweden, Israel, England)Global Express 3 - 4 days $30.00Global Priority 4-6 days $15.00If you have any further questions please let me know.I am just trying to get what I paid for the parts back since I am not doing the motor extension.If anyone is interested in them please let me know and we can arrange getting them to you.Thanks,Simeon amburgeySound Creations, Inc.www.soundcreationsinc.com/midibox
Guest Perka Posted November 18, 2002 Posted November 18, 2002 Hi, Im in need of 8 motor faders, but i live in sweden.Problem? How much do you want for them?Does this faders have touch sensors?What is touch sensors used for? :-)/Pär
Guest Simeon Posted November 19, 2002 Posted November 19, 2002 Hello,You can email me privately with your mailing specifics and I will se what it will take to get these to you.These are the Panasonic motorfaders which are not touch sensitive but Thorsten has made a great circuit available to accomplish this.The touch sensitivity is useful when trying to change parameters while you have automation going. it allows you to disengage the motor to make adjustments.Hope that helps,
ThomasT Posted November 19, 2002 Posted November 19, 2002 >Thorsten has made a great circuit available to accomplish this. -verbose
TK. Posted November 21, 2002 Posted November 21, 2002 -verbosethanks for the reminder ;-)However, here a schematic of the touch sensor circuit which will be supported with the next MIDIbox MF version. In theory it could also work with other MIDIboxes as cheap button replacement, but this will not work until I've added the special charging pulse signal at Port J14http://www.ucapps.de/mbhp/mbhp_din_touchsensors.pdfBest Regards, Thorsten.
Guest Simeon Posted November 21, 2002 Posted November 21, 2002 I also have the support chips and other parts for the MotorFader extension.Thanks..
Guest Perka Posted November 21, 2002 Posted November 21, 2002 Hi, I may be dumb(probably), but how do i use thiscircuit with the panasonic faders without toch sensors?/Pär
LO Posted November 21, 2002 Posted November 21, 2002 Dont know for sure as I havent played around with it yet (I have the panasonic faders), but it would appear you only need to add buttonsAlthough the Firmware seems to detect when you move the fader manually and switch off the fader (without touchsensor track) not perfectly but pretty well.
