sfred Posted February 24, 2022 Posted February 24, 2022 Please help me! I want an OLED display for the sammichSID. I need an 8-bit LCD driver. I can't compile ASM code ... I haven't been able to configure it yet ... Please have someone compile a sammichSID firmware. I will send a modified ASM file if I need to ... Grateful thanks!
sfred Posted February 25, 2022 Author Posted February 25, 2022 I read a lot of guides. Successfully compiled ASM code. The OLED display works well with an 8bit driver. If anyone needs the firmware, here is: setup_sammich_sid_8bit.hex 3
latigid on Posted February 26, 2022 Posted February 26, 2022 Great that you learned the mysteries of compilation! I uploaded your file to the wiki page too:http://www.midibox.org/dokuwiki/doku.php?id=sammichsid
cube48 Posted March 14, 2022 Posted March 14, 2022 On 2/25/2022 at 9:09 AM, sfred said: I read a lot of guides. Successfully compiled ASM code. The OLED display works well with an 8bit driver. If anyone needs the firmware, here is: setup_sammich_sid_8bit.hex 223.19 kB · 1 download Thanks for the effort! I've tried it with Optronics Raystar (D2-P6-3) but I get garbled characters. Do I need to do any extra wiring (like mentioned in sammichFM OLED thread)?
sfred Posted March 29, 2022 Author Posted March 29, 2022 Don't be mad at the late reply. Yes, the "Jumpers" must be soldered together at the bottom of the PCB Check connect: PIC Pin 10 RE2 to J16:D3 PIC Pin 9 RE1 to J16:D2 PIC Pin 34 RB1 to J16:D1 PIC Pin 33 RB0 to J16:D0
cube48 Posted March 30, 2022 Posted March 30, 2022 Thanks a lot for coming back! I'll give it a shot.
