Hello Thorsten,
re the audio ins on your multi sid I notice you've disabled them in the connection diagram but have still got the ext in led on the filter area of the control surface.
Any particular reason for that?
I'm building a multi sid with similar layout and control surface to yours. I,ve just ordered the sid, dins, douts boards from smash. I built the core modules from his boards too. Great quality.
Keep up the excellent ideas, designs etc.
Cheers Jorge  :)
Also a reason is to remind to use Audio plugs with conns connected to ground if nothing is plugged in (if you dont do it you will get much of humming in there).
And as far as I know TK isn't using those Ins to much anyhow...
Thats the only reason. Greets!  :)
