Guest Allen Posted March 16, 2004 Report Posted March 16, 2004 Hi all,I'm building a Midimon using a complete core kit I purchased from SmashTV. I'm getting no characters on my LCD, and belive I'm missing something in the hookup.The details: The LCD is from Crystalfontz, p/n CFAG123864B-YYH-V, a 128x64 with built in inverter using a KS0108 compatible controller. The core seems to be functional after MIDI flashing using MIOS 1.6 and the main.syk file. When I power up the core I get 1 burst of sysex and then no output, which seems normal. I have a 10k pot between the -5v out of the LCD and gnd with the wiper going to Vo of the LCD, and can see the contrast of the LCD change as I turn the pot- so that seems to be working.I'm unsure if the RS pin from the core should go to RST pin of the LCD, or if it (the reset line) should be tied high (it is active low). Also, the LCD has a D/I line to determine if the incoming byte is data or instruction, but I don't know where to connect this to the core. Sorry to be so verbose, but this is my first LCD project- any help would be greatly appreciated.Allen
xile Posted March 31, 2004 Report Posted March 31, 2004 Hello Allen,Having the same problem, looking without success to figure out how to connect the d/i pin on the lcd. Have you had any luck?xile
TK. Posted March 31, 2004 Report Posted March 31, 2004 Hi,it's important that the LCD type is set to #1 in the MIOS ID header (if this hasn't been done by SmashTV, you have to use the change_id application).D/I replaces the R/S signalBest Regards, Thorsten.
xile Posted April 1, 2004 Report Posted April 1, 2004 Hello Thorsten,I'll try connecting the RS pin from the core to the D/I pin of the LCD and update the topic with the results.I'll also check the LCD type in MIOS ID header, but I'm pretty sure I set that correctly.Does this mean that there is no connection required to the RST pin of the LCD? In my configuration, every other core to LCD pinout matched except the RS, CS3, and CS4 or the core and the RST and D/I or the LCD. If the RS from the core connects to the D/I of the LCD, that still leaves the CS3 and CS4 of the core unconnected. Is this a problem?Thanks.xile
TK. Posted April 1, 2004 Report Posted April 1, 2004 Hi,RST is the reset line, it depends on the display if it has to be connected or not. In fact there are 5 possibilities:*general answer mode on*no reset pin: thats the common casefloating low-active reset pin (reset with logic-0): add a pull-up resistor (10k to +5V) so that the display is not in reset state after power-onfloating high-active reset pin (reset with logic-1): add a pull-down resistor (10k to ground) so that the display is not in reset state after power-onlow-active reset with internal pull-up: let it openhigh-active reset with internal pull-down: let it open*general answer mode off*How to find out the type of reset pin? Normaly it can be read in the datasheet, and if not, try an external 10k pull-up first (in most cases the reset line is a low-active input) - if it still doesn't work, try a pull-down.CS3 and CS4 are output signals of the core, so: no problem. You could connect a second KS0108 type display in parallel to the first one, with the only difference that the chip select lines are connected to CS3/4 in order to double the resolution (nice for MIDIbox LC)Best Regards, Thorsten.FAQMARKER
