dott.benway Posted June 24, 2022 Posted June 24, 2022 Hi all, I'm trying to resurrect a old MIDIBOX SID that I have built for an eurorack modular synth project. My setup is composed by the following: 1 16x2 LCD display GDM1602B Xiamen ocular 1 mbhp core made by smashTV running PIC18F452 BSL V1.2B MIOS V1.9E 1 SID board made by smashTV , 8580 is installed the application is setup_8580_without_cs.hex In past the system was working perfectly but the cable connections where unstable, so I have decided to rewire It. After the rewiring I have double checked all the connections but the system doesn't work anymore. I have also checked all the voltages . the synthoms are the following: 1) the display is blank (no messages, only a solid rectangle at the system boot) 2) after the system boot the SID is generating a loop of 4 notes like an "alarm tone" 3) Sending a Query in MIOS studio stops the "alarm tone" with the following message: Operating System: MIOS8 Board: MBHP_CORE or similar Core Family: PIC18F Application is up & running 4) Sending notes in MIOS studio results only in audible "CLICKS" Have you any suggestions about? Any hint would be very appreciated. Thanks, B.R. Giorgio.
dott.benway Posted June 25, 2022 Author Posted June 25, 2022 Hi All, a little update. I have removed a short circuit in the display connector. Now the weird alarm sound is gone and the SID module is up and running. Unfortunately the LCD display doesn't work. Maybe I have damaged a GPIO of the PIC. B.R. Giorgio.
Antichambre Posted June 26, 2022 Posted June 26, 2022 On 6/24/2022 at 9:10 PM, dott.benway said: the application is setup_8580_without_cs.hex If I remember well display is part of the CS, so it will not initialize with the firmware you use. But maybe I'm wrong. BR Bruno
