creekree Posted April 9, 2004 Posted April 9, 2004 i was wondering if it would be possible to use those oooooldschool windshield-wiper-lookalike thingies to display midi activity (one for in, one for out)i am asking this because i have a nice tabletop amplifier case that would be perfect for a midibox64, and it already has those things (what are they called???) in it.is it possible? after all, they are analogue unlike a LED.creekree www.asphaltgleiter.de
TK. Posted April 10, 2004 Posted April 10, 2004 Hi Creekree,it should work with the same circuit which is used for LED indicators (LTC module). Maybe you've to change the 10 uF caps to a 1 uF or lower for best visual results...The LTC sends pulses on every MIDI event, than more pulses over time, than higher the deflection of the needle (such a measure behaves like an integrator)Best Regards, Thorsten.
