SounDuke Posted May 6, 2004 Author Report Posted May 6, 2004 Yes I printed the master on transparency pardon...Well I don't think I have to peel the paper because I made it and the result was that I had a copper board without photoresist in one hand and a piece of paper white above and black below.. maybe with a 60W solar lamp I have to expose for more time than 35 minutes Quote
Synapsys Posted May 6, 2004 Report Posted May 6, 2004 Hi SounDuke,The white paper on the board is there to protect the photoresist during shipping. It MUST be removed before exposing the board. The light used to expose the board must be an ultra-violet fluorescent type. An ordinary incandescent lamp will not work. Take a look a this web site for detailed description of the process.http://www.mgchemicals.comHappy etching... Quote
SounDuke Posted May 7, 2004 Author Report Posted May 7, 2004 Thank you Synapsis ;)Ordinary lamps will not work, but Solar lamp will work. Electronics sellers say "you must buy a fluorescent tube" which costs a lot. I succesfully impressed a board with solar lamp, the blue ones, 60w power which costs 1€. well my etched board looks ok, the only problem is that there is a VERY slight asimmetry in a corner due to unproper simmetry of the masters. it's very slight, i speak of a track wich is at least 0,01 mm larger than the printed one. do you think it is a big problem? Quote
arumblack Posted May 7, 2004 Report Posted May 7, 2004 What I had problems with was straight lines or slots.perhaps if you built some sort of jig to hold the tool, or had waaaaayyyyy more time and patience than me....If i only had a mill......even a non cnc one...... Quote
Synapsys Posted May 7, 2004 Report Posted May 7, 2004 Cool on the solar lamp. It must have light in the UV band. As long as the traces are intact and not shorting to other traces there should be no problem. Quote
SounDuke Posted May 8, 2004 Author Report Posted May 8, 2004 I think I etched a good board. However, I'm not sure if the copper was well- corroded. I don't see copper between tracks and outside the circuit, but my tester shows infiniteKohm when i touch with + and - the tracks, 0Kohm when I touch the plastic panel. I can't understand these values.. Is the board ok? Quote
