Guest the_al Posted July 13, 2004 Report Posted July 13, 2004 hi :)I wanted to know if someone has built and completed successfully a MB (espiecally a MB LC) to use with a ProTools system.which kind of emulation is suggestable? I have red about the MotorMix emulation.. is that good?is there a way to emulate the HUI protocol?bye, daniel.
jeroddumas Posted July 13, 2004 Report Posted July 13, 2004 I've been on the quest to emulate HUI, but to no avail. I'm in the process of building a Motor Mix. I'm collecting the equipment right now.
Guest the_al Posted July 14, 2004 Report Posted July 14, 2004 do you know, if it's possible to add a master-track fader using the motormix emulation?like in the HUI controllers.daniel ;D
jeroddumas Posted July 14, 2004 Report Posted July 14, 2004 There is no implementation for a master fader in the motormix protocol.
Guest the_al Posted July 14, 2004 Report Posted July 14, 2004 ok, thanks. now I've seen the notes of the M_Emulation of Thorsten and I now what i can do with that protocol and ProTools.see you, good work .. :)daniel
