banneduser Posted August 9, 2004 Posted August 9, 2004 Sorry for the novice Question...Can anyone explain what is the difference between detend and non-detend rotary encoders? I want to order encoders from Voti, should I take detend or non-detend? Any one had any expirience with them? I'm going to use them for midi box (not a sequenser).ThanksnW
banneduser Posted August 9, 2004 Author Posted August 9, 2004 Sorry for the novice Question...Can anyone explain what is the difference between detend and non-detend rotary encoders? I want to order encoders from Voti, should I take detend or non-detend? Any one had any expirience with them? I'm going to use them for midi box (not a sequenser).ThanksnW
banneduser Posted August 9, 2004 Author Posted August 9, 2004 Hi,Detend encoders have "clicks" between the steps.Non-detended ones move smoothly between the steps.But that's not all: With a midibox, non-detend encoders use "quadroubled resolution", so 24step /rotation encoders give you 96 steps.This can't be done with detend encoders: You probably don't want to see parameters to jump 4 values in one step.At least ALPS detend encoders can be easily modified to non-detend ones, but as far as I remember, no-one has confirmed this on votis encoders.Bye, Moebius
banneduser Posted August 29, 2004 Author Posted August 29, 2004 Thanks.I order Voti's encoders. those are great. They have nice feel. and by removing a little spring from the inside of the encoder - you can un-detened them.I enjoy them.
illogik Posted August 29, 2004 Posted August 29, 2004 the detented encoders of voti can also be modified; bend the 4 clips (that hold the encoder together) back with a mini screwdriver, open the encoder. In the bottom there is 1 "u-shaped" pin with a bump in the middle. If you bend this pin down so it wont touch the upper part when reassembled, your encoder will be non-detented.cheers, marcel
Jurbo Posted September 16, 2004 Posted September 16, 2004 I have a bunch of Voti's encoders waiting to be assembled into a SID Control Surface.I'm thinking of undetenting them. A question: if the "click" is removed, does the enc still send only pulses, so it won't be "on all the time" between the original clicked positions?Another, possibly stupid, question: if I remove the "click" from Voti's encoders, will the resolution be quadrupled (I sure don't want that!)?Thanks for advice.Dual SID CS construction status: Completed 1 core module, 1 SID module, 1 dinx module and LCD module  :)
illogik Posted September 16, 2004 Posted September 16, 2004 if you remove the click like i described above, the only thing that happens is that you dont feel the detents anymore; the pin you bend is only there for the "feel" (detented); it has nothing to do with the actual "working parts" of the encoder..i've undetented all my voti encoders for my sid CS, works fine for megood luck with building,cheers marcel
