RadicalAns Posted August 13, 2004 Posted August 13, 2004 I'm a bit confused by the switches in the scematics for the c64 power supply (both regular and optimized). Are there two seperate switches used or is that a single DPST switch?
RadicalAns Posted August 13, 2004 Author Posted August 13, 2004 I'm a bit confused by the switches in the scematics for the c64 power supply (both regular and optimized). Are there two seperate switches used or is that a single DPST switch?
moebius Posted August 13, 2004 Posted August 13, 2004 Hi,I think it's referring to recycled C64 power switch.. and you can use DPST :)Bye, Moebius
