ChriSu Posted December 31, 2023 Posted December 31, 2023 ...maybe not the perfect category, but here is my problem: Since ever (15 years) I am unhappy with what I get when I play digital music with my M-Audio Keystation Pro 88. (Huge latency, strange sounds, etc.).....but I am not yet willing to give it up and buy a different one. Now I found that when I release a key, it sends the MIDI command "Note off XX Velocity 0" I think this is wrong: it should either be "Note on XX Velocity 0" or "Note off XX Velocity 127". (....when I use a different keyboard that sends "Note off XX Velocity 127", there is no issue) First question: is it likely that software as well as my Behringer Neutron get confused from "Note off XX Velocity 0"? Second question: can I use MidiBox to receive MIDI commands, send the good ones and correct the bad ones, or would that create huge latency? Thank you, Christian
TK. Posted January 1, 2024 Posted January 1, 2024 Hi Christian, I agree that your keyboard doesn't handle Note-Off messages correctly. According to the MIDI Spec (-> https://web.archive.org/web/20071005165318fw_/http://www.borg.com/~jglatt/tech/midispec/noteoff.htm ) the default velocity should be 64 if not supported, but it sends 0 instead. Your other keyboard sends 127, which is actually also wrong if it doesn't support this feature - but somehow works better. Actually it's recommended that keyboards send Note On with velocity 0 to turn off the note, because this keeps the runtime status, ensures that no extra byte has to be sent out and therefore saves some time (ca. 320 uS) Behringer Neutron: either sets a very long release time (e.g. for VCA envelope) with Note Off Velocity 0, or it doesn't handle Note Off correctly -- 0 is a valid value and if there is no special processing for this velocity value, it should be handled like any other. Quote Second question: can I use MidiBox to receive MIDI commands, send the good ones and correct the bad ones, or would that create huge latency? This would add +1 mS latency, which is acceptable. Best Regards, Thorsten.
