Rednas Posted August 25, 2004 Posted August 25, 2004 Part of this discussion has already been written in the diode matrix discussion, but maybe this is a better place for my and your ideas. Or wiki, but I doesn't seem to work right now.Here is my idea to midi conversion to pipe organ.About: Organ pipes controlled with midfied console.When I came to this website and read about the MIDIO128 I also thought it can be used to control pipes and make a unit organ. This means one rank of pipes use different stops, with different transpose (1 octave, 2 octave, - 1 0ctave, 2 1/2 octave etc.)My idea is this:We have input:1,2 or 3 manuals + pedal realtime midi input from different channels: note on type.Stops pulled input: This contains: division (what manual) What Rank (Prestant, Trompet, Flute) What Height 16', 8' , 4' etc (8' = 0 transpoze, 16' = 1 octave down, 4' is one octave up. ' stand for feet. The longest pipe on 'piano pitch' C is 8 feet. 16' = twice as long = twice as low = one octave down.)For this we can use different midiboxes or the one with a huge matrix input in development right now.We have output:Up to 16 ranks. With 128 or less pipes. These pipes can be controlled by midimesseges, note onoff, on the right channel. This means noteon messages received on channel 1 will be used to open or close pipes on rank 1 (Prestant for example), messages on channel 2 will control rank 2 (Flute). etc. For this we can use a MIDIO128 for each Rank/Channel, which controls the ranks.Next step: processing.I don't know C and just have little experience with Java, but here is some quick code.We an use a midiprocessor for this purpose. We get a lot of cores in this way, but I think that works fastest and is easiest to explain for now. Later we can bring it all to less midiboxes.in the midi processor we need some matrixes: SP1, SP2, SP3, SPP (stopspulled1, stopspulled2, stopspulled3, stopspulledPedal.The best thing is to put thes in to a main matrix SP= {SP1,SP2,SP3,SPP}In this matrix we save what stops are pulled.SP* look like these: Rank / Channel Transpoze 0 1 2 3 4 etc. 15Height 16' -12 0 1 0 0 0 0 0 8' 0 0 0 1 0 0 0 0 4' +12 1 0 1 0 0 0 0 2 2/3' +19 0 0 0 0 0 0 0 2' +24 1 0 0 0 0 0 0 1 3/5' +28 0 0 0 0 0 0 0 1 1/3' +31 0 0 0 0 0 0 0 1' +36 0 1 0 0 0 0 0 (looks not to good, but I don't know how to get it better)This is a 8*17 matrix. This makes SP a 4*8*17 matrix. But different sizes can be made according to the pipes and ranks that are available. A normal church organ would only use the 8' height.Stops pulled are: 4' and 2' at channel 0, 16' at channel 1, 8' and 4' at channel 2.First consider a noteon event:9n xx vv n = channel xx=pitchFirst we check the channel.channel=n;Originalpitch=xx; (Save original pitch because messages will contain transposed pitch)volume=vv; (either 0 or normal noteon value)For r=1;SP[channel,length] ; for all rows. We first process one row and send the pitch ;belonging to that channel to all ranks(channels) for which the ;stop is pulled.pitch = originalpitch + SP[channel,r,0] ;Change pitch.For k=1;SP[channel,r,length] ; for all kolomns.if SP[1,r,k]=1 ; check if stop is pulled/ if note has to be sent on this channel.send 9k pitch volume ;send corresponding noteon message with right pitch to right channelEnd ;for k=...End ;for r=...How to fill SP.When a message is received that a stop is pulled/unpulled, the corresponding matrixentry has to be set/unset.The best thing to do is, i think contain this all in the stop message:Stop messageYn pp vvY= A,B,C whatever is not used. We may need to, for on/off.n= channel corresponding to pedal, manual I etc.pp = pitch, /determines heightvv= volume. /determines rankIf .... Stop on message is received.Division=n;Height=pp;Rank=vv;SP[Division,Height,Rank]=1.If .... Stop off message is received.Division=n;Height=pp;Rank=vv;SP[Division,Height,Rank]=0.Coupling:Maybe this can de done in the midibox, the manuals are coupled to: send midibyte on two channels.Problems to be solved:Noteoff.This could be a problem when using say 8' and 4' on one channel. Say you press c1 and c2 together, but release c2 first. Then you get a noteof message for c2 on your rank, but it should be one, because the 4' at c1 adresses c2 also. I will think about this. Any suggestions?For a normal organ only working with 8' it's no problem, except if the manuals are coupled.Stopoff.If you put a stop off, you cannot turn the pipes off anymore, because apropriate midi messages will not be send. This means we need a noteoff on that channel, or for everynote pressed on that channel and height. This is another difficulty that will have to be overcome, or an imperfecty we have to live with.What we need, except for the pipes I can't afford yet :-(, is a program in C to process the input and manage the output. The SP matrix can be different for everybody using this, but it will be no problem to adjusting this in the main code. I am willing to write this program in the future, for the midiprocessor, although I don't now C yet. Is there anyone who need this program in the near future? To check I luckily don't need all the pipes :-)YoursRednas
jimhenry Posted August 25, 2004 Posted August 25, 2004 What you propose is possible but very ambitious. If you want to do that, I think it will be better to learn PIC assembler than C.Since you can't afford the pipes right now, have you tried any of the virtual organs? Hauptwerk http://www.hauptwerk.co.uk/ is good for classical organs. My program, Miditzer http://www.miditheatreorgan.com/, is a theatre organ, highly unified in the way you propose. jOrgan http://www.meiers.net/sven/ is written in Java. Not only will these give you some immediate gratification, they will give you a chance to learn more about how organs work.There are commercial solutions for connecting consoles to pipes. Unless you value your time at nothing, you probably will come out ahead using a commercial solution. Look at Opus Two http://207.236.55.58/users/opustwo/index.html for example.
Rednas Posted August 25, 2004 Author Posted August 25, 2004 It is amibitious indeed, but I thought this is a bit what you wanted too. And there are some problems to overcome as I told already, but if that is done it should work.PIC assembler may indeed be easier/better than C. I don't have discovered how all of MIOS work, so I don't know what to use yet. I thought of altering the MIDIprocessor program for this purpose, and use whatever it is using.I use jOrgan at the moment. I use two keyboard and just bought a pedalboard from an organ builder. If connected the reedcontacts already, but am waiting for a midiconnection board. Monday I discovered this site and it will be usefull for the rest of the organ console I think. Especially if the matrix input works fine. In this way I can practise warm and dry at home at all organ literature whenever I have spare time. I can play at some organs in the neighbourhood too, but not always, and I have to go there and it can be cold in the winter.It would be nice to have a real organ at home. With real pipes. With the console I'm building I can adres them. And in this way I can connect and buy one rank at a time. Time should not be the problem yet.I will look into opus two. What was your idea at controlling pipes with midi exactly?yoursRednas
jimhenry Posted August 25, 2004 Posted August 25, 2004 My idea is that I don't want pipes at home. The care and feeding of pipes is just more than I can handle in my house. I do all the things you talked about in a C++ program running on a PC. Since I use PC hardware, SoundBlaster, to generate the sound it doesn't matter to me whether the relay function is done on the PC or in the MIDIbox. Putting the relay in a PC rather than a MIDIbox means I don't need to think so hard about being efficient. I only need MIDIbox to convert console keyswitch contacts to MIDI.Are you planning to use the switch matrix in your project? If so, I better get busy and release something for that project.
Rednas Posted August 25, 2004 Author Posted August 25, 2004 Are you planning to use the switch matrix in your project? If so, I better get busy and release something for that project.I am. I ordered parts this week, so next week I can put stuff together. Then I must also build the drawknops with it's contacts and some preset buttons etc. Than Crescendo pedals and maybe manuals instead of synthesizers. But to use all this I really like the matrix. I don't know how much buttons it will be, but I think I can also test some part of the program before it will be officially bug free and released.
Rednas Posted August 25, 2004 Author Posted August 25, 2004 Since I use PC hardware, SoundBlaster, to generate the sound it doesn't matter to me whether the relay function is done on the PC or in the MIDIbox. I also don't care yet. jOrgan works fine. But maybe later it will be better without computer and with pipes.
jimhenry Posted August 25, 2004 Posted August 25, 2004 I am [using switch matrix]. I ordered parts this week, so next week I can put stuff together. Then I must also build the drawknops with it's contacts and some preset buttons etc. Than Crescendo pedals and maybe manuals instead of synthesizers. But to use all this I really like the matrix. I don't know how much buttons it will be, but I think I can also test some part of the program before it will be officially bug free and released.Is your plan to get the MIDIbox working first and then connect the console to the MIDIbox incrementally? That is the approach I am using because once the MIDIbox works it becomes a fast way to check the console wiring. You can temporarily configure stops to send Note On/Off and hear whether things are working as you go.Will your MIDIbox be a CORE, DIN, and DOUT? If you have a full DIN and DOUT it is easy to change the dimensions of the matrix by changing the software. I hope that changing the software will be easy too. ::) Have you made any decisions about what matrix dimensions you will use? I chose to make my DIN 32 bits wide to allow large groups of switches to share a common bus. I have a wired pipe organ console that I am working on and it has 122 key contacts on a common bus. I'll have to divide that into 4 busses. I will use 16 DOUT bits to select busses to give me 512 inputs. If I made the matrix 24x24 I could get 576 inputs with the same number of wires but I would have to divide my keyboards to have 6 busses.Right now, I have an 8x8 matrix working. If you want something other than 16x32 I should do that next as it sounds like you are closer to wiring something up than I am. So far I have half of my diode matrix built and it will be at least another month before that is finished. It will probably be another month after that to assemble the whole MIDIbox which will be a panel that goes in the back of the console to receive all the existing console wires, none of which is color coded or identified. Then I start tracing hundreds of wires to connect the console to the MIDIbox.
Rednas Posted August 26, 2004 Author Posted August 26, 2004 Good idea to test the wiring with the midibox. For my pedal I used a self fabricated testset with one led and two batteries. It works fine, but I had only thirty contacts. The pedal uses a common bus for 4. So that could easily be tested for 8 or more.Manuals:I don't have these yet. For the pedal I made wiring. I planned to use a manual from an old organ. This would have one common bus I think. No second touch for me :-). I think this is a common thing to do. It is not to much trouble to cut it in two or three, if you don't use the organ anymore. But I think cutting in two will be best. So 32 is a good number. I can also construct wiring for existing manuals. I have some here from old harmoniums, but without springs, so I have to fix that too. Or I'll take a look on the internet if someone has some for sale.I ordered 2 Cores, 1 Dout, 2 Din, 1 Ain and a JDM. This would be enough to experiment with right know. I've made plans for a common organconsole, for three manuals and pedal and planned 4*10 stops on both sides of my console. But maybe these dimensions will change. Maybe this will change for a unit organ. But that can also be done later.I think 16x32 is fine. If not I can also redirect the wiring for this project. I will think about it when the console is ready.
Rednas Posted August 26, 2004 Author Posted August 26, 2004 I forgot to tell:The preset buttons wil not be to hard to make. When they are ready I can easily test all combinations for the 16x32 matrix. So if you need some help i'm here for you.
johnh Posted August 27, 2004 Posted August 27, 2004 >> We have output: Up to 16 ranks.>Why limit yourself to 16 ranks? I
Rednas Posted August 27, 2004 Author Posted August 27, 2004 John, nice organ console. I guess that pipes are working too, with MIDIO128 or something? What is your setup? Pipes and hauptwerk or something?You're right. Limitation to 16 ranks is not necessary but easy. In this way you use the 16 midi noteon channels for noteon messages. You could use more filters, or extra channels like 5n. Another possibility is sending messages for two ranks of 64 pipes on one channel, using all 128 notes. But this is an extra difficulty. 16 ranks can be enough for a regular organ. Remember 16 ranks for all manuals, since it is midi driven. If you have a unit organ, every rank can have multiple stops like 8', 4' 2' etc. So 16 ranks mean a few dozen stops on each manual. This must be enough for the regular home organ.For software it is not that much. But with the soundblaster soundfonts, you're limited by the polyfony of 64 for each card. That's why I have 3 pluged in right now :-). Thanks to kxproject. (Link can be found ot jOrgan website). Polyfony 64 means 8 notes with 8 stops, so I can have 8 notes with 24 stops. And if this isn't enough, I'll buy another card :-)But limitation is not necessary. We have to remember that there is not too much latency through the midifilter though.
Rednas Posted August 28, 2004 Author Posted August 28, 2004 I came up with a better idea instead of the matrix. To use  ordinary variables and use the bits as data. For each height we need two or three bytes. This depends on wether we will you the first bit as a register. In normal midi messages this one is always zero. If we stick to normal midimessages we need three to cover 16 bits. So for instance we have for 8' 0x26 0x63 0xC0In bits: 00100101 00100011 11000000Forget the bits that don't count:0100101 0100011 11or better to read:0100 1010 1000 1111This means midi messages at this channel will be forwarded to output channels 2,5,7,9,13,14,15,16In the function the bits can be read . If 1 a midi message will be sent, if not, read the next bit and raise the midichannel.For the stops we need an apropriate midi message.For instance ;;  PROC Received Bn: called on a Controller Event;;  In:    MIDI_LASTEVENT0: Bn, n = midi channel;;    MIDI_LASTEVENT1: CC number;;    MIDI_LASTEVENT2: CC valueThe strong point of this method is: we can use the xor functions to toggle stops. Set and unset is not supported in this way. That would be another routine. And all stops off message will be implemented.1000 0000 0000 0000Will toggle channel 1 when xor is used with the bytes in memory.0100 0000 0000 0000Will toggle channel 20010 0000 0000 0000Will toggle channel 3We had0100 1010 1000 1111Now we toggle channel 2 so we have:0100 1010 1000 1111xor0100 0000 0000 0000Will give 0000 1010 1000 1111Pull channel 1 will give0000 1010 1000 1111xor1000 0000 0000 0000=1000 1010 1000 1111Another advantage: Presets can be implemented directly. First send an all stops off message. (To be implemented)Then send a bunch of messages for each channel and each heightlike send 1010 0000 1000 0000 for 8'and 0100 0001 0010 0000 for 4'etc.To set 8' on channels 1, 3 and 94'  on channels 2, 8 and 11I'm trying to program this for PIC16F877 in the MIDfilter/processor. Jim Henry, you can wait for this or use a computer program. Maybe both is als a good idea. I hope this helps you too. It can make a standard language you were looking for I think. Any recommendation for codes to use, two or three bytes or other stuff?I must find out how to make variables, but I think it will be somewhere in the help file of MPLAB.
Guest profleo Posted August 28, 2004 Posted August 28, 2004 So for instance we have for 8' 0x26 0x63 0xB0In bits: 00100101 00100011 11000000IMHO 0x26 0x63 0xB0 equals, in bits:00100110 01100011 10110000
Rednas Posted August 28, 2004 Author Posted August 28, 2004 Thnx. You're right. It's a bit new to me, Hex. I will edit my message for this.
Rednas Posted August 30, 2004 Author Posted August 30, 2004 I've been busy, and have code like this so far. IT IS NOT FOR THE PIC18... but for the PIC16.....First implement variables:I did this in main.*Stop variables consist of three bytes.Cblock 0x20 Pitch Channel Velocity Ranks StopsP16:3 StopsP1023:3 StopsP8:3 StopsP4:3 StopsP223:3 StopsP2:3 StopsI16:3 StopsI8:3 StopsI513 ....ENDCTo route incoming messages according to manual/channel:PROC_Received9n movf MIDI_LASTEVENT0, W ;; get event byte #0 xorlw 0x90 ;; compare channel with 0 skpz ;; skip next command if equal goto PROC_PEDAL ;; for all manualsThis is used to send messages:PROC_SEND ;;used to send output midimessages to 'pipes' movf channel, W call MIDI_SendByte movf pitch, W call MIDI_SendByte movf velocity, W call MIDI_SendBytereturnVelocity is original velocity. For each manual there is a routine to redirect the messages according to the values of the height and ranks, and adjust channel and pitch to that.PROC_PEDAL;;===============================================================================;; this will handel messages coming from PEDAL (ch0);; In: MIDI_LASTEVENT0: 9n, n = midi channel;; MIDI_LASTEVENT1: note number;; MIDI_LASTEVENT2: velocity movlw 0x90 ;;midimessage for channel -> W movwf Channel ;;load channel 0 in channel movf MIDI_LASTEVENT1, W movwf Pitch ;; move note number to pitch movf MIDI_LASTEVENT2, W movwf Velocity ;;save velocity message in velocity;;-----------------------------------------------------------------------------;; process all stops for Pedal;; StopsP16:3;; StopsP1023:3;; StopsP8:3;; StopsP513:3;; StopsP4:3;; StopsP223:3;; StopsP2:3;;------------------------------------------------------------------------------;; StopsP16:3 ;; adjust pitch movlw 0x0C ;;12 subwf pitch,1 ;;pitch-W->pitch ;;check if midibit has to be sent on channel. if it does, do so immidiately wth PROC_SEND BTFSC StopsP16,1 ;; if this bit is 1 GOTO PROC_SEND ;; send message at channel 0 INCF channel ;; increment channel BTFSC StopsP16,2 ;; if this bit is 1 GOTO PROC_SEND ;; send message at channel 1 INCF channel ;; increment channel BTFSC StopsP16,3 ;; if this bit is 1 GOTO PROC_SEND ;; send message at channel 2 INCF channel ;; increment channel BTFSC StopsP16,4 ;; etc GOTO PROC_SEND INCF channel BTFSC StopsP16,5 GOTO PROC_SEND .... BTFSC StopsP16+1,3 GOTO PROC_SEND INCF channel ..... BTFSC StopsP16+2,2 GOTO PROC_SEND INCF channel This for all stops.Next step, pulling stops.;; ==========================================================================;; THIS WILL IMPLEMENT PULLING STOPS;; It assumes same message for pull or withdraw;; The message contains three bits with it's own function.;; n, midi channel: What midichannel does the message belong to.;; n%4 = midi inputchannel notedata;; midi channel modulo 4 = midi inputchannel notedata;;;; Channels 0 to 11 are used.;; 0,4,8: channel 0/ pedal;; 1,5,9: channel 1/ manual I;; 2,6,10 channel 2/ manual II;; 3,7,11 channel 3/ manual III;; Note number:;; Defines tranposition;; Not all are used.;; Transposition = notenumber-24 (36);; note number tranpose in feet;; 0 64';; 12 32';; 24 16';; 31 10 2/3';; 36 8';; 43 5 1/3';; 48 4'etc.goto right manual:PROC_ReceivedAn;;check to which manual;;1010rrmm;;two bits of rr define ranks (byte 0, 1 or 2);;two bits of mm define manual (0,1,2 or 3) movf MIDI_LASTEVENT0, W iorlw 0xFC ;; 1010rrmm ior 11111100 = 111111mm ;; 1111 11mm xor 1111 11nn = 0000 00pp xorlw 0xFC ;; manual = 0 -> W = 0 skpnz goto PROC_PEDAL ;; manual != 0 -> W = 0000 00mm xorlw 0x02 ;; manual = 2 -> W = 0 skpnz goto PROC_MANUALII goto right rankPROC_STOPSP;; a stop is pulled for pedal;; determine which rank;;MIDI_LASTEVENT0 = 1010rrmm;;two bits of rr define ranks (byte 1, 2 or 3);;two bits of mm define manual (0,1,2 or 3) clrf ranks incf ranks ;; 0:1 1:1 2:1 BTFSC MIDI_LASTEVENT0, 4 ;;Check 5th bit of MIDI_LASTEVENT0. goto PROC_STOPSPR3 ;; only if it is 2 0:1 1:1 2:2 BTFSC MIDI_LASTEVENT0, 5 ;;Check 6th bit of MIDI_LASTEVENT0. goto PROC_STOPSPR2 ;; only if this is one goto PROC_STOPSPR1 ;; 0:0 1:1 2:1 returnPROC_STOPSPR1;; Stop processor Rank 1 ;; First data byte is used. We have the right manual and the right rank number.;; Move to second databyte.;;;; Note number:;; Defines tranposition;; Not all are used.;; Transposition = notenumber-24 (36);; note number in feet;; 24 0001 1000 0x18 16';; 31 0001 1111 0x1F 10 2/3';; 36 0010 0100 0x24 8';; 48 0011 0000 0x30 4';; 55 0011 0111 0x37 2 2/3';; 60 0011 1100 0x3C 2;; StopsP16:3;; StopsP1023:3;; StopsP8:3;; StopsP4:3;; StopsP223:3;; StopsP2:3 movf MIDI_LASTEVENT2, W xorwf StopsP16 ;; pull stop in memory. movf MIDI_LASTEVENT1, W xorlw 0x18 ;; w= 0 if 16' skpnz return;; apparently stop was pulled in memory. Leave this routine movf MIDI_LASTEVENT2, W xorwf StopsP16 ;; unpull stop 16' xorwf StopsP1023 ;; pull stop 10 2/3 ' movf MIDI_LASTEVENT1, W xorlw 0x1F ;; w= 0 if 10 2/3' skpnz return movf MIDI_LASTEVENT2, W xorwf StopsP1023 xorwf StopsP8 etc.Things to do: Cancel all stops for one height (in cas of hangers. / all notesoffImplement presets. I said earlier this will be easy, but not with the routine used now, because after one pull is detected, it leaves the routine. It's an awfull lot of text, but thanks to copy, paste and replace the workload is much less ;D
John_W._Couvillon Posted April 8, 2005 Posted April 8, 2005 Hey Rednas,There have been over 3000 replys on this thread since I asked the first question, and it has been some time since I participated.However, I have a working console, 2 manual and pedal board with working stops and swell shoe, and have been very successful running jorgan, including version 2. My original concept was to utilize midi to construct a pipe organ, and I am still on that course. Presently I have acquired a blower capable of 5 ranks or so, a 16' subbase rank, 4' diapason rank and part of a 2' salicional. I have also amassed a store of wicks and reisner magnet valves. Most of this I scrounged, and I am still in the hunt.I presently have two midio128 cores working in the keyboard encoder area with 4 DINS on one and 3DINs on the other. I received today another DIN to add to the second core so that I can add pistons and couplers.My console is a Moller artiste which I had to partially re-wire.I am in the process of working out the overall design for the additional cores and DOUTS to drive the pallet magnets.I do want to retain the ability to use Miditizer, jorgan or Hauptwerk. The approach I am taking is more straight forward, using the basics of mios and the midio128 without custom programming, of which i know little. therefore, I am very interested in your work with MIOS, in particular for stops, pistons, memory and couplers. My organ must play without a computer attached.Send me your email address and I will share what I have done with you.All of this has been done using other pic processors, boards, etc., by several including petrov, so I am sure that it can also be done using midibox technology and programming.I suggest you read back through the thread on this subject. There is a wealth of good information including the tough of the master, Thorsten Klose.Regards,Johnc
gu Posted August 30, 2005 Posted August 30, 2005 Hi Rednas,I am from Italy, and I am in constructing my real pipe organ, too. the real pipes are real pipes!Have you solved your two problem, wrote in your first post?--> Noteoff.This could be a problem when using say 8' and 4' on one channel. Say you press c1 and c2 together, but release c2 first. Then you get a noteof message for c2 on your rank, but it should be one, because the 4' at c1 adresses c2 also.--> Stopoff.If you put a stop off, you cannot turn the pipes off anymore, because apropriate midi messages will not be send. This means we need a noteoff on that channel, or for everynote pressed on that channel and height.I want to use a midi0128 for each rank of pipes (or at least two), that keep in memory what stops and what solenoid must play for every midi channel (keyboards and pedalboard). I think this solution is easy. I have channel 1-3 for keyboards and channel 0 for the pedals and the decoders midi0128 all connected on cascade metod by midi throw.But I had not think to your two problems.... If you have solved them let me know!.Thank a lot,Gu.
KealyPaul Posted October 28, 2005 Posted October 28, 2005 Thanx, Per ... this is exactly the kind of applicationI was seeking.This is how I have configured my present working modelBaldwin/MidiTzer hybrid, dedicating a particularkeyboard solely to the Roland Sound Canvas, and why Irefer to it as my "Antiphonal/enChamade" manual. documented atTheatreorgans.com/StentorVoxThis keyboard is not accessible from any otherkeyboard or intramanual piston, and that's OK with me.It is definitely not a floating division out there,and most designers would think it kinda klutzy, but itworks for me.I think of this keyboard as a separate organ thatshares a manual keyboard within the real estate of theconsole. I must simply select a Sound Canvas MIDIinstrument for it to connect to (piano, carillon,brass trio, whatever) from the Sound Canvas itself(that's why I have the face plate of it incorporatedinto my Baldwin console design for easy access).Why could not a particular manual send MIDI commandsto a switchbox to actuate an horizontal wall-mountedrank of enChamade pipes or actuate grandma's pumporgan across the room, or play a melody on vibes (likeat Lorin's studio), or actuate a simple swell chestwith particular pipes within it ... that would servemy need (as long as they were in tune with theMidiTzer keyboards, heh!).It is an "either / or," not a "both / and" situation froma designated MIDI keyboard that resides within theconsole, unconnected from the other keyboards that are unified with each other.Do you get my drift?I mentioned I am working from a foam coreboard frameconsole mockup of my gutted Wurli, using labeled tongue depressor tabs and MIDI keyboards for an eventual production console design.It is more similar to those consoles that operateplanetarium shows than an actual organ, I guess, so I know I am pretty far afield. Hence, the need for me to devour all I can on thisforum before I present my true desires to anorganbuilder. The ones I've talked with really raisean eyebrow ... 'nuf sed.Some of the green and blue tabs on my unique organhave nothing to do with organ whatsoever; I havemerely expanded the capability of those organists whotrigger mirror balls and spotlights or controltoycounter effects from their instruments.Because I use an NSI MIDI-controlled theatrical lightmixer for my productions, I know it is possible toincorporate MIDI for non-musical controls.Why could I not employ such non-musical triggers ascomputer up/down cues for my PowerPoint and9-projector multi-media slideshow, as well as electricmotors for curtains, waterfalls, etc.?When, may you ask, does a person have time to performorgan and still operate all these gadgets? That's avalid question, I have to admit ... "Don't pay anyattention to that green man behind the curtain, Toto!"(heh!).Of course, these non-orgel tabs will be duplicated on a separate dedicated MIDI production console via a duplicate MIDI stream for a technician to operate with video remotes, etc., but the museum show producer in me may have a desire to work through the midnight hours without an entire staff to operate the controls as I tweak and create.Although I am a producer limited in performancetechnique, I believe theatre unit-orchestra can fill aneed for today's audience (that resorts to mosh pitsand violent on-stage theatrics because they haven'tbeen exposed to the full potential satisfaction ofwhat a contemporary organ can provide in a live mediaapplication performance).
John_W._Couvillon Posted March 11, 2006 Posted March 11, 2006 Hello Paul,I am sure that Per S has given you some good advice concerning your project. I also am a recepiant of his advice and can't say enough about his patience and help.In your research, you should take a look at jorgan (http://jorgan.sourceforge.net) and log in on the forum (http://jorgan.sourceforge.net/forum/index.php?sid=defc131555d02937d23b381073edf5ca) jOrgan is a virtual organ similarly constructed as miditzer, but capable of operating from from a conventional console without need of a computer monitor. The monitor is necesssary and helpful, but not needed at the console. In addition, jorgan can be configured to trigger pipe magnets for use concurrently with the electronic ranks.My project is to build a hybrid organ using jorgan and pipes. My console is a moller 2 manual which was converted to midi using the midibox technology. So far there are 3 ranks of pipes with companion blower, regulator, windchests, etc., and I am in adding the driver boards, etc. for powering the magnets. With jorgan, you have a choice of staying with a classical organ or theater (cinema) organ as you like. jorgan is capable of functioning as the master control system, and can do just about anything that you can do on a conventional organ console.I would be glad to respond in greater length by email if yo so desire ( jwcouvillon @cox.net).Regards,johnc
jimhenry Posted March 12, 2006 Posted March 12, 2006 The Miditzer is also capable of being used without the computer screen, mouse, or computer keyboard. It is just less aparent since the Miditzer is designed to make it very easy for a new user to get started and so it presents those interfaces as something everyone will have. You can also drive any output device you want including MIDI controlled pipes. Again less obvious because the Miditzer tries to be sure everyone will hear something without effort. I believe jOrgan now has a way to tie a rank to a specific MIDI channel which is needed for real pipe control but that has always been inherent in the Miditzer.
John_W._Couvillon Posted March 27, 2006 Posted March 27, 2006 Jim Henry,Do I understand that miditzer now supports driving pipes? Would you explain how to do this.Jorgan allows you to output to a soundsource which can be a remote midi device. In my case it is a midibox Core with Dout cards attached. The output comes from a midisport USB 2x2 adapter and feeds the core directly. Does Miditzer work in a similar fashion? Can you set which channel you want to output on? For those that are also interested in driving pipes, congratulations goes to Smashtv for the new Revision 3 to the Dout cards. One option with the cards is to install ULN2803 darlington drivers.
jimhenry Posted March 27, 2006 Posted March 27, 2006 The Miditzer has always output MIDI. A long time ago the channels were fixed but they have been configurable for quite awhile. If your pipes are driven by MIDI then the Miditzer could drive them.
stryd_one Posted March 27, 2006 Posted March 27, 2006 Hi guys, I'm sure that while you are doing this stuff, you'll be far too busy for documentation, but I really hope that when you're done, you'll share some of this very specialised knowledge that you've gained, at the wiki :) Edit: Terrible typos.
smashtv Posted March 27, 2006 Posted March 27, 2006 I'm sure that hile you are doing this stuff, you'll be far too busy for documentatino, but I really hope that when you're done, you'll share some of this very specialised knowledge that you've gained, at the wiki :) 110% agreed on this.....you guys have the ability to inspire so many by showing off some real world control.You balance things out here in a big way by doing something thats not a "synth thing"...... ;)I'm always having to try to explain to people in person what I do, so I start by handing them a core board, then I fire up the palm to show pictures......Keep in mind I live in redneck hell, so it goes something like this:"studio controllers" while showing off the big guns from the gallery....blank confused stare...."old school synths" while showing off the quadsid and playing a sample mp3.....again blank confused stare...."pipe organs" with more pics on the palm.....the "idea bulb" pops up over their head, and something like "oh wow" comes out of their mouth.:)BestSmash
jimhenry Posted March 27, 2006 Posted March 27, 2006 Agreed about needing to get some documentation about this branch of MidiBoxes into the Wiki. Check out this proud owner and his MidiBox:There is nothing in that console but MidiBoxes and maybe audio amplifiers.Some Miditzer users are working on a box that converts three expression controllers to MIDI. This will be a good starter project because it only uses a core board.
